NEW SOS - SINGLE POD INSTALL
Old Oct 14, 2007 | 07:49 PM
8178A's Avatar
8178A
Default RE: NEW SOS - SINGLE POD INSTALL
ORIGINAL: drbobvs
Are they standard 2 1/16" gauges that can be mounted in an A-pillar pod?
I think that would be a better solution so you could put it back to stock when you sell the car.
Old Oct 14, 2007 | 08:17 PM
Stkjock's Avatar
Stkjock
Retired Mod
ORIGINAL: drbobvs
Do you need both gauges, or did you mount 2 so you can read 4 things simultaneously?
you can buy them in singles... since I had none I went with 2 to have 4 displayed .... u can acutally set them to "scan" and alter the display in set intervals.
They are standard 2 1/16 but were a bit loose. Alan @ SOS suggested (and it worked perfectly) to use small strips of the soft side of Velcro on the back side of the gauges.
As far as drilling the dash.... I really never thought twice about it.
Old Oct 14, 2007 | 08:52 PM
hammeron's Avatar
hammeron
nice job, they look great.
no more sleeper, but it's worth it
Old Oct 15, 2007 | 10:50 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Looks great and the aero gauges seem to be all the rave these days!
Old Oct 16, 2007 | 01:00 PM
Stkjock's Avatar
Stkjock
Retired Mod
ORIGINAL: mygt500
They were just released for the S197 about 4 weeks ago or so....and the install is fairly easy... if your using the SOS Pillar Pod you could do it in 15 mins or less!! and you get 2x as much info per gauge...
Old Oct 16, 2007 | 01:31 PM
banka87's Avatar
banka87
Are you plugging the guages into the port? Or are they like hardwired in?
How hard is it to change the readouts?
I'm VERY interested in these.
Old Oct 16, 2007 | 01:36 PM
MustangEsq's Avatar
MustangEsq
I am seriously considering these also Dave....I'll have to see them once I get my car back!!!
Old Oct 16, 2007 | 02:34 PM
Stkjock's Avatar
Stkjock
Retired Mod
ORIGINAL: banka87
it plugs directly to the OBD port..no hard wiring necessary. if you want to use the analog inputs w/ sensors (MAP or A/F) u'd hard wire those. the readouts are very easy to adjust. two small push buttons on each gauge for adjusting thru the menu.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
