Cold weather is back
Old Oct 16, 2007 | 06:07 AM
2cokeman's Avatar
2cokeman
Default Cold weather is back
Just a comment, Now that the cool-cold weather is back so are all the interior rattles and squeaks, especially the dash, that I had hoped worked themselves out during the summer, NO SUCH LUCK[sm=smiley35.gif]
Old Oct 16, 2007 | 06:09 AM
PLstang's Avatar
PLstang
Default RE: Cold weather is back
Yep the cold weather is back! It's supposed to be 72 today!
Old Oct 16, 2007 | 06:12 AM
2cokeman's Avatar
2cokeman
That doesn't help us suckers up north![:@]
Old Oct 16, 2007 | 06:24 AM
PLstang's Avatar
PLstang
Sorry, that is cold for us!
Then agian you weren't here when we were 105! Luckily the humidity was only 98%![:@]
Grew up in Ohio though so I know what you mean!
Old Oct 16, 2007 | 06:34 AM
jmk3's Avatar
jmk3
But the cold air makes sooooooo much more power!!!!
Old Oct 16, 2007 | 07:54 AM
Rdot9's Avatar
Rdot9
DubStep Stu
yeah, cold air is nice, snow is no fun though[:'(]
Old Oct 16, 2007 | 08:14 AM
rom8bszfh2cg5q7s4pap's Avatar
In the auto industry, they call these exterior/interior noises BSRs (bumps, squeaks, rattles). Over time, you'll hear more and more of them, not less. That's how it works.
If you work on this car, you'll see things like small pieces of felt tape, spongy foam, zip ties, etc. These things are usually put in place after a BSR is found by the engineers or quality inspectors. The vehicles are put on shaker tables and put through varying frequencies to simulate the roughest of road conditions. When a BSR is found, Ford calls the automotive supplier of that component to fix the problem. Sometimes the fixes are termed "band aids", such as applying felt tape or zip ties. Other times they require a redesign of the part, which can be costly.
The emphasis with my comment is that these "band aid" fixes may not last very long, leading to a return of the BSR.
So, next time you see a piece of felt tape anywhere on your vehicle, rest assured that it was put there as a quick fix.
Old Oct 16, 2007 | 08:22 AM
STORMEASTON's Avatar
STORMEASTON
ORIGINAL: PLstang
I hate you!
Old Oct 16, 2007 | 08:27 AM
TPony's Avatar
TPony
Nope, no such luck in Washington State...stationary front = rain for the next two years....[:'(]
Old Oct 16, 2007 | 08:30 AM
PennState's Avatar
PennState
not bad weather currently its only 45!
