Tire dillema
Ok first of all please please please dont move this to the rim and tire section nobody ever checks it!
Anyway, for xmas im going to be getting some 18x9 and 18x10.5 staggered black fr500's. For the past week i've been searching trying to find just the right size tire for these rims, i've tried tire size calculators and looked just about everywhere and i still cant decide. Ok pretty much what looks best with this combo? Im not going to be lowered so im not looking for a super low profile sidewall, i also dont want a huge bulging mass of rubber and i dont really want the front tires to look larger then the rear as far as height goes. What are the best/most common sizes for the front and back? Picks of stock ride height with this combo size would be appreciated.Thanks guys!
*btw yes i have used the search function and cant find what i need. unless someone cant point me to a thread i may have missed.
If you don't plan on lowering your car I would recommend the Nitto 555's. Go with the 295/45/18 out back and the 255/45/18 in front. They do a pretty good job of filling up the wheelwell, although I still think i'm gonna lower mine at least an inch all the way around.
Here are my pics...
http://s11.photobucket.com/albums/a1...ics/?start=all
Here are my pics...
thanks for the help guys! so is there any big advantage of going to a 255/45 instead of a 245/45? just more tire im guessing. Im still used to my new edge and how a 245/45 fit the front quite nicely.
ORIGINAL: 00silverStang
295/45/18 out back will change your speedo readings as it is a taller tire than the stock 27.1 inches.
285/40/18 out back is 27.1 inches tall so you speedo won't be off.
You can correct with the handheld but remember, going with a taller tire in the rear will be effectively dropping your rear gear ratio, from a 3.55 to a 3.31. I didn't do the math so it may not be that much but you get the idea.
