door lock doesnt work with key
Old Oct 19, 2007 | 03:19 PM
olfrt's Avatar
olfrt
Default door lock doesnt work with key
Any one have a problem opening the drivers door with the key on a 2006 mustang ? mine only opens with the remote. thanks.
Old Oct 19, 2007 | 04:46 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: door lock doesnt work with key
Pull the inner door trim panel and fix it.
There is probably only a clip missing or broken.
Or take it in for warranty work to the dealership.[:@]
Does the key turn but do nothing or will the key not
even turn?
Old Oct 19, 2007 | 05:24 PM
vmaxman2's Avatar
vmaxman2
My problem with the drivers door is the lock doesn't open when you use the automatic unlock on the drivers door. I always have to reach over and pull the handle. The one time it worked was when I brought it back to the dealer for something else. It hasn't worked since I brought the car home. Murphy's law.
Old Oct 19, 2007 | 05:26 PM
vmaxman2's Avatar
vmaxman2
Sorry, correction. The passenger lock doesn't function.
Old Oct 19, 2007 | 05:31 PM
birdoffire7's Avatar
birdoffire7
ORIGINAL: vmaxman2
Are you pressing the unlock button on the fob (key remote) twice to unlock the passenger side? It's a security feature, press once for drivers, twice for passengers to open as well.
Old Oct 19, 2007 | 05:33 PM
birdoffire7
ORIGINAL: olfrt
Sounds like you need to take a trip to the dealer. Hopefully you're still under warranty.
Old Oct 20, 2007 | 08:36 AM
157dB's Avatar
157dB
Cut & Paste Expert
READ THE OWNERS MANUAL
My Bad.
WSOTB syndrome
Old Oct 20, 2007 | 09:21 AM
bmk's Avatar
bmk
its 2 different people asking 2 questions.. the OP asked about the key in the door and someone else asked about the fob only unlocking the driver door
Old Oct 20, 2007 | 02:40 PM
olfrt's Avatar
olfrt
The key will not turn the lock toward the unlock position if the door is locked. if I unlock the door with the remote, the key will turn the lock to the unlock position also to the lock position, locking the door, but then will not unlock it again. it seems as if there is some sort of electric stop placed in front of the key action until the lock is unlocked with the remote. the owners book is not clear on this. thanks for any help with this. I had the car in the dealer last week to replace the fuel pump and a switch on the fuel vapor system that was causing a fuel cap light on the display, all warranty work so far. guess ifI have to I can go back again, I just want to be sure it is not something I can correct with switchology.
Old Oct 20, 2007 | 03:14 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: olfrt
El NopeO. YouS gots the Problem Os
Stealership-squeelership time for you.
Take some lube if its not covered under warranty.
Heck, mine could be that way also. Never once
have I used the door key to get in. Might scratch
the paint by accident...[:@]
Now if my battery dies thats another story. I guess
its trunk to rear fold down seat entry for me.
No scientology will work for you here. Its key
fob remote for the rest of its life or a trip to the
"we scratched your paint by mistake" stealership.
Or your lock is fixed, now your door rattles like
a snake. Or that big ol grease spot on your seat
was there when you brought it in. Or not sure why
your front tires are flat spotted.
Whoops.
Where are my happy pills....
