long tube headers
how hard are they to install on a 07 gt? i am just mainly interested in a high quality , deep throaty tone. also will they cause me more problems than they are worth? any info would be very helpful. all i will be running is a tune and cai.. thanks
I can tell you they are pricey to have installed. It requires quite a bit of work from what I have read. You will also need to consider that the mid pipe will have to be changed. I think you will also need a set of mill extenders or have your tune corrected.
Can't tell you much more then that, hope that helps a little.
They are do-able if you have free time and don't mind a challenge. They shouldn't cause you any problems unless they are installed incorrectly or you don't retune the car. PLstang is right though, they are pricey to go have installed. In the end they will give you some more hp and make the exhaust sound deeper.
I did it myself with a buddy. Took us about 5 hours. It's really not too bad, just time consuming. We had to take off the motor mounts and lift the motor, take off the starter and some other minor stuff. I found removing the battery and tray and the CAI makes it easier. Good luck with whatever you do!
I installed mine (shorty's) and it took me 10 hours... I also did my springs and shifter that day so thats why it was it slightly longer... very time consuming... need to remove motor mounts... lift motor... get a tune... new midpipe... etc. The members above this post pretty much covered it all -- JayFreaky is correct when his said taking out the minor stuff will make things easier... I did the same so if gave me more room to work. ~ J
I have the JBA's and their direction say anywhere from 10 -13 hours to install.... umm yeah... didn't feel like being raped either so I did it myself... [8D] ... then again I heard it only hurts the 1st time... lol! jk
ORIGINAL: Thurman
zesty-that guy was trying to rape u in broad daylight.
