Air Bag Light - Error Code 23
Old Oct 21, 2007 | 08:53 PM
clustersnarf's Avatar
clustersnarf
Default Air Bag Light - Error Code 23
On the way to the bowling league tonight my Air Bag dash light started blinking. I plugged in the Diablosport tuner when I got home and it shows no error codes... Clearing error codes did nothing as there were none to really clear. The manual says to see the dealership (duh). Just wondering if anyone has seen this behavior before and what it happened to be.
The light blinks with someone sitting in the passenger seat and without. Note, this is NOT the Air Bag Off light on the console, this is the Air Bag Icon on the Tach Side of the house. Maybe just an electrical malfunction somewhere. Anyone had this happen before?
Old Oct 21, 2007 | 09:50 PM
underbird10's Avatar
underbird10
Default RE: Air Bag Light
I had this problem at about 5K. My light would blink on startup and it was blinking a code "23". You can figure out the code by counting the blinks yourself (count the number of blinks in the first code digit, it'll pause for a second, then blink the second code digit). The blinking pattern will repeat about 3 or 4 times then the light will come on solid. My car also showed no fault codes in the PCM.
Turns out a code "23" was the airbag in the passenger seat which was replaced by the dealer under warranty. Been fine ever since.
UB10
Old Oct 21, 2007 | 09:52 PM
ohsixgt1217's Avatar
ohsixgt1217
Was your bowling ball in the passenger seat?
Old Oct 21, 2007 | 10:01 PM
Burnsy's Avatar
Burnsy
that wouldnt matter, he said this isnt the passenger airbag on/off light, this was in the dash, tach side, and that it occurs with and without people on the pass. seat
Old Oct 22, 2007 | 07:46 AM
clustersnarf
Just the old ball and chain, as it were.
ORIGINAL: ohsixgt1217
Old Oct 22, 2007 | 07:47 AM
clustersnarf
Cool. I'm about 6K right now. Guess I'll be calling my dealer and taking it in... thx for the info
ORIGINAL: underbird10
UB10
GidyupGo's Avatar
GidyupGo
Same light on mine would come on ever so often. Dealer did some probing and found out that there was a place under the driver's seat where the wire had rubbed a bare place on it and it would ground out against the seat frame when the seat was just right.
Old Oct 22, 2007 | 07:58 AM
banka87's Avatar
banka87
On my car, whenever someone sits there, the airbag OFF light comes on, and will turn off if they squirm around for a little while haha
Old Oct 22, 2007 | 09:34 AM
cookiemonster's Avatar
cookiemonster
Did any of the power connectors under your seat(s) come loose? If one did, you'll need to depower the SRS, reattach it, then repower the SRS.
Old Oct 22, 2007 | 10:06 AM
clustersnarf
I havent looked yet. But I did count the blinks. It is the 23 code... 2 blinks, pause, 3 blinks, pause, Full on light. Any reference for the 23 code before I go off to the dealership. Such as. What cables to look at, etc. I really dont relish the dealer tearing apart the dash. Maybe they could fix that GOD FORSAKEN RATTLE over there . It was on my 2005 and its on the 2007.... Same rattles and buzzes.... C'mon FORD, FIT AND FINISH!...
ORIGINAL: cookiemonster
[edit] Fixed some spelling issues...
