BMR LCA's and relocation bracket
I've searched all the threads on "traction" , "suspension", "control arms", etc. Still confused whether I need relocation brackets for the BMR LCA's if I'm not lowered. Alot of posts say you need them, some don't. Question: Will just the BMR LCA's (without brackets) help wheel hop, and does it help MORE with the brackets when you're not lowered?
I plan on going with a 1 pc. DS and adjustable UCA in the future...
Thanks.
Thanks.
That's a great article. Thanks!
I understood how they work, but needed to know a little more about the improvements to traction and wheel-hop with non-adjustable LCA's w/o relocation brackets. Not sure as to how much the OEM control arms "flex" with basic bolt on power, but it seems like the bushings play a bigger role at that level.
ORIGINAL: Bmr4life
Gotta question. Who makes an adjustable LCA that has the Poly/Spherical rod end combo. IE, Poly on one end and Spherical on the other.
BMR offers non-adj poly-poly, non-adj poly-Spherical, adj poly-spherical, and adj spherical-spherical
I plan on the adj poly-spherical for a few reasons
