Cowl Leak into the cabin.
Old Oct 25, 2007 | 08:14 PM
rslaurie's Avatar
rslaurie
Default Cowl Leak into the cabin.
We had a pretty good rain in the DC area last night. When I got into my car this morning I had an inch of water on the floor on the passenger side.Every time the care moved, more water came out from under the dash. I immediately went to the dealer. They thought it quite odd. After checking it out, they said it was a bad cowl seal. Has anyone heard of this or had this problem? I have an '05 GT, had it or 2.5 years and never had a leak until now.
I had a similar problem with a 10 year old '84 Cavalier (nolaughing please)several year years ago and it turned out to be the drain from beneath the cowl was clogged and so overflowed into the vent intake. Should I look for a cowl drain? Anyone know if there is one, and if so, where it would be?
Old Oct 25, 2007 | 08:26 PM
americaniron's Avatar
americaniron
Default RE: Cowl Leak into the cabin.
It is a big problem with the new stang there is a TSB out for it. I had the problem too. Tell your dealer to repair it in accordance with TSB 07-14-6 Good luck.
Old Oct 25, 2007 | 08:33 PM
hammeron's Avatar
hammeron
sorry to hear it, but the dealer will
take care of it for you
Old Oct 25, 2007 | 08:34 PM
Burnsy's Avatar
Burnsy
https://mustangforums.com/m_3038957/tm.htm
particularly
16128 WATER LEAK RIGHT FRT FLOOR BOARD GETTING WET WATER LEAK TEST FOUND RIGHT FRT FLOOR BOARD SOAKED. WATER COMING IN FROM RIGHT FRT COWL PANEL PINCH WELD. R&R CENTER CONSOLE ASSEMBLY REMOVE DASH ASSEMBLY TO ACCESS COWL PANEL. RESEAL COWL PANEL. REMOVE RIGHT OUTSIDE COWL PANEL AND INSPECT RETAINING CLIPS FOR LIFTING UP. KNOWN FOUND LIFTING UP. DID RESEAL RIGHT SIDE BODY SEAM AND REMOVE ALL RETAINER CLIPS APPLY SEALER TO BACK SIDE AND REINSTALL INTO COWL PANEL SHEETMETAL REASSEMBLY DASH AND RETEST FOR LEAK NO LEAK FOUND AT THIS TIME. REMOVE WET CARPET DRY CARPET AND FLOOR BOARD INSTALL NEW JUTE PADDING REINSTALL CARPET REINSTALL CARPET REINSTALL CENTER CONSOLE OK AFTER REPAIR. M-TIME FOR JUTE WORK BODY
Old Oct 26, 2007 | 09:38 AM
Leoleo's Avatar
Leoleo
Welcome to the water leak saga!
Old Oct 26, 2007 | 09:59 AM
rslaurie's Avatar
rslaurie
Thanks for the help guys. Burnsy, is the repair you list a quote from the TSB? Americaniron do you know where I canprintout a copy of the TSB. I don't see it in the list of TSB's on the forum.
Thanks again.
Old Oct 26, 2007 | 10:21 AM
157dB's Avatar
157dB
Cut & Paste Expert
Its the underdash water dispenser.
The ice part is broken.
I didnt order it, but I got it.
Welcome to the club.
Old Oct 26, 2007 | 12:46 PM
Leoleo's Avatar
Leoleo
Water Leak TSB
Old Aug 25, 2011 | 12:33 PM
tangs05's Avatar
tangs05
Default Cowl leak
The guy who had a cowl leek. I had the same problem with my 2005 mustang. There is a drain under the cowl. Mine was clogged with those pesky little helocopters from trees. I took the grommets out from the cowl and put my hand down in there and unclogged the drain and presto no more leeks. Hope this was helpful.
Old Aug 25, 2011 | 12:38 PM
tangs05's Avatar
tangs05
This is a simple fix. Go under hood and remove those clips that hold the cowl in place. Put your hand down in the reservor and find the drain. It is probably clogged.Mine was and I unglogged it and no more leak.
