LCA Install Help
Old Oct 27, 2007 | 04:57 PM
sailing220's Avatar
sailing220
Default LCA Install Help
When I did the right side, I had no problems. Now I'm doing the left side.
I put one end of the LCA in, and it seems that it is too "short" for the other side to reach. How do I get it in there?
Old Oct 27, 2007 | 05:13 PM
DarkFireGT's Avatar
DarkFireGT
Default RE: LCA Install Help
If you're supporting the car on the frame rails, jack the axle up and bit and you'll be able to move it into position.
Old Oct 27, 2007 | 05:17 PM
sailing220's Avatar
sailing220
It is on the frame rails. I tried what you suggested, but it still felt like it wouldnt budge? Will it only work if it is on both rails and not just one? I tried that as well...
Old Oct 27, 2007 | 06:12 PM
Boss919's Avatar
Boss919
With jack stands on the frame rails and the rearend sort of hanging I used a ratchet strap and pulled it to line the bolt holes up.
Old Oct 27, 2007 | 06:26 PM
moosestang's Avatar
moosestang
If these are adjustable control arms then just lengthen it.If not then you should be able to lineit up by placing a floor jack under the center of the axle and jacking it up.
Old Oct 28, 2007 | 03:48 AM
User 113021's Avatar
User 113021
Have someone push towards the front of the car on the tire. That's what I had to do.
Old Oct 28, 2007 | 08:35 AM
jmk3's Avatar
jmk3
+1 on the ratchet strap
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
