SLP Brake Control Package
Old Oct 30, 2007 | 06:49 PM
southernmustangparts's Avatar
Former Sponsor
Default SLP Brake Control Package
The SLP brake-control package allows you to save your rear brakes...
Press the brake pedal and flip the brake-control solenoid switch. Remove your foot from the pedal, and the solenoid maintains line pressure to the front brakes until the switch is released. This makes it easy to heat the rear tires in the burnout box, while minimizing wear and tear on your car's rear brake components. You can also use the system to prevent a manual-trans car from rolling out of the staging beams at the starting line. A must have for you serious racers.
This kit is custom-fitted to the Mustang chassis (no tweaking or fabrication required!) and is fully compatible with the factory anti-lock braking and traction-control systems. It includes a waterproof electrical solenoid, an activation switch, plug-in wires, CNC-bent steel lines with correct OE fittings, mounting hardware, and detailed installation instructions.
Check them out at www.southernmustangparts.com or just click here
http://www.southernmustangparts.com/...age-p-116.html
Cheers
Ken
Old Oct 30, 2007 | 06:58 PM
Thurman's Avatar
Thurman
Default RE: SLP Brake Control Package
um uh... line locks?
Old Oct 30, 2007 | 07:15 PM
Former Sponsor
ORIGINAL: Thurman
This product is also referred to as: Roll Control, Line Lock, Line Loc, Launch Control, Anti-Roll, Stage Control and Roll Stop.
Also have them available for the 2007 4.6 Mustang GT's
Cheers
Ken
Galactic
Apr 29, 2019 02:56 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
Sep 8, 2015 11:50 AM
