Dreaded Check Engine Light
Old Nov 2, 2007 | 06:17 PM
Mustangansta's Avatar
Mustangansta
Default Dreaded Check Engine Light
since i cant search the forums for this simple topic because the search section seems to be non functional - can anyone help -
i have the check engine light on and dont know why - seems to be running fine - just came on out of the blue -
DTC - P2198 O2 Sensor Signal Stuck Rich is the code i got back from the sct scan - -
help??? !!!
*06 GT - SCT tune 93 oct - - jlt cai - long tubes - axle backs -
Old Nov 2, 2007 | 06:18 PM
DeStonn's Avatar
DeStonn
Default RE: Dreaded Check Engine Light
how many miles?
check the gas cap
use a sct or predator to read the error code
Old Nov 2, 2007 | 06:23 PM
sawyer's Avatar
sawyer
check for codes first, then take your tune back to stock and then re load your custom tune and see if it comes back.
Old Nov 2, 2007 | 06:34 PM
Mustangansta
i'll try resetting - by the way i edited and reposted what code came up;
help??? !!!
Old Nov 2, 2007 | 08:41 PM
downriverT's Avatar
downriverT
Thats the same code I have been getting but my car goes into failsafe mode also. I go WOT and the car reads failsafe mode and shuts off. Its the only code that I get now(before I had a whole list of them but I think I took care of the rest). Im taking mine tommorow to get serviced hopefully they will work on the car. At all other throttle positions the car is fine. I'll let you know what Ford says tommorow.
Old Nov 2, 2007 | 09:16 PM
Mustangansta
re set it - put in stock tune - then uploaded 93 perfomance oct tune and light is gone............... for now
Old Nov 2, 2007 | 09:19 PM
hammeron's Avatar
hammeron
P2198 02 Sensor Signal Stuck Rich (Bank 2 Sensor 1)
let's see if it comes back after resetting
Old Nov 2, 2007 | 09:35 PM
allj's Avatar
allj
ORIGINAL: Mustangansta
help??? !!!
Do you have long tubes oran x pipe.
Old Nov 3, 2007 | 04:19 AM
Mustangansta
long tubes and xpipe w/ high flow cats -
light off - just re flashed computer . now the question is why did it give me that code in the first place.
Old Nov 3, 2007 | 10:24 AM
downriverT's Avatar
downriverT
Check the throttle body. Just got back from Ford service and say everything was coming from the throttle body.
