Ventalation Controls
Old Nov 14, 2007 | 05:06 PM
gln3's Avatar
gln3
Default Ventalation Controls
Last Sunday I had the first opportunity to use the heat in my Mustang for the first time. When I turned the control to put heat at the floor I was getting a lot of air at the windshield (defrost) vents. I turned the control **** to defrost and could not tell much if any difference in flow. Is the normal for our cars?
Old Nov 14, 2007 | 06:01 PM
blackonblack2007's Avatar
blackonblack2007
Default RE: Ventalation Controls
You probably selected the bi-level, which is right above the defrost if I am not mistaken. (Don't use my heater here in hawaii). Bi-level puts air through the defrost vents and the floor vents.
Old Nov 14, 2007 | 06:52 PM
laserred02's Avatar
laserred02
mine does the same thing, and no it isn't on bi-level. not sure if it is normal or not, i suppose we'll see what others say.
Old Nov 14, 2007 | 08:59 PM
sleeper2's Avatar
sleeper2
Mine works fine, but I'm almost sure I remember reading about a TSB (service bulletin) about that very problem a while back.
(Well I looked at the TSB's and I can't find anything about it. I guess I was mistaken.)
Sleeper2
Old Nov 14, 2007 | 09:19 PM
owero01's Avatar
owero01
Mine does the same thing. I'll ask my service manager if its by design.
Old Nov 15, 2007 | 05:29 AM
gln3's Avatar
gln3
I was not using the Bi-Level position, using floor only.
Old Nov 15, 2007 | 05:41 AM
Caution's Avatar
Caution
Hrmm -- I never noticed it before... out here in CA and rearly use the heat
Old Nov 15, 2007 | 06:41 AM
06elnr's Avatar
06elnr
mine does it to, I posted about it two days ago, i dont know if its normal...
https://mustangforums.com/m_4183700/tm.htm
Old Nov 27, 2007 | 04:21 PM
gln3's Avatar
gln3
Had my Mustang in the shop today for ventalation (heat) situation. Mine is putting a lot of air out the defrost (windshield) when in the heat (floor) mode. Service department checked with Ford and was told this is by design. So to make sure went out to lot and checked the stable and all of them have the same situation.
Old Nov 27, 2007 | 04:35 PM
07RedfireGT's Avatar
07RedfireGT
I guess mine isn't working right then because i live in Iowa and have been using the heater quit a bit lately and comes out on floor normal and defrost is normal also.
