Suggestions ?
Old Nov 21, 2007 | 10:13 PM
gnrpatience's Avatar
gnrpatience
Default Suggestions ?
Hello,
This weekend i was on the road and was running my pony at 120MPH-140MPH lot of fun! Everytime i was pressing the brakes i felt the car like it was vibrating, i thinkis normal but it was a very very little vibrating, what can i use to avoid this?
Many Thanks
Old Nov 21, 2007 | 10:44 PM
rshamekh's Avatar
rshamekh
Default RE: Suggestions ?
I had this happen to me before. Took it to the dealer, they cleaned (grinded) the surface of the front rotors.
Problem solved. Free under warranty!
Old Nov 21, 2007 | 10:50 PM
Ford_Dude's Avatar
Ford_Dude
140 sure is fun don't you think
Old Nov 21, 2007 | 11:02 PM
Boozshey's Avatar
Boozshey
My brakes were shot after a few trips on the autobahn while I lived in Germany... Just to hot I believe...
Old Nov 22, 2007 | 04:07 AM
Orion_240's Avatar
Orion_240
yeah, the brakes aren't up to the task. Not even in the same ballpark as the 300 hp stock engine. Just regular spirited driving on the freeway can cause fade.
I'm not sure if vibration is normal though...
Old Nov 22, 2007 | 04:08 AM
Orion_240's Avatar
Orion_240
What brake kit are most people upgrading too?
The GT500's?
Old Nov 22, 2007 | 06:00 AM
probinator's Avatar
probinator
Bigger brake kits cost from 1500-3k
I would just find a nice pair of cross drilled for the front with some hawk pads. If you have the money go cross drilled with new pads all the way around.
Old Nov 22, 2007 | 08:22 AM
Boozshey's Avatar
Boozshey
I found a front and back BAER kit on ebay last night for $1800, best deal I had ever seen. To bad I don't got the loot to buy it.
Old Nov 22, 2007 | 12:00 PM
gnrpatience
So normaly if you run your car like at 120MPH or 140MPH and you press the brakes do you feel something weird with your ´stang ?
I felt the car a little weird is just a little a very small vibrating but i wonder if its normal cause the speed is too high.
Many Thanks
Old Nov 22, 2007 | 12:23 PM
157dB's Avatar
157dB
Cut & Paste Expert
I feel it also.
Its probably not normal, though.
