Shifter thread size???
Old Nov 21, 2007 | 10:29 PM
thewarmachine's Avatar
thewarmachine
Default Shifter thread size???
I installed a Steeda Tri-Ax shifter today, and I find out that my stock shift **** won't work with it even though Steeda claims it will. The tri-ax threads are too coarse for my stock shift ****. My **** is the aluminum one in the 2007 GT appearance package. Anyone know what size threads the tri-ax has? Not sure how to measure that. Is the GT appearance **** threaded finer than a regular stock **** or is Steeda off its rocker?
BTW, I HIGHLY RECOMMEND THE TRI-AX! BEST SHIFTER EVER. SO SMOOTH! NOT FLOPPY OR RATTLY, BUT NOT TOO STIFF EITHER. BLOWS HURST OUT OF THE WATER!!!
Old Nov 22, 2007 | 12:39 AM
thewarmachine
Default RE: Shifter thread size???
Anyone at all got any info on this? Come on all you Tri-ax owners.
Old Nov 22, 2007 | 05:29 AM
300GT's Avatar
300GT
got my Steeda catalog in front of me. The product description for the Tri-Ax doesn't mention thread size for shifter, but right below that is the product description for their billet shifter *****. They offer one for the Tri-Ax and one for "factory shifter", which would seem to confirm what you already found out - they're not threaded the same! Guess that's one way to get you to buy another product from them. Glad you like it though - I've read all your posts about the troubles you had with the Hurst.
Old Nov 22, 2007 | 08:21 AM
MTAS's Avatar
MTAS
If memory serves, Steeda screwed up the threads (no pun intended) early on in the Tri-Ax's production for S197's and put the thread pitch for SN95 ***** on there. The stock S197 shift **** uses M12x1.25 threads, SN95 stock ***** use M12x1.75.
Old Nov 22, 2007 | 10:32 AM
thewarmachine
Thanks guys. I'm not sure what I'm going to do yet. I want a shifter ball, but I was considering ordering one of those long chrome shifter sticks with white ball from Jegs, and cutting it to length and drilling holes to fit my tri-ax. That way I'd have a quality shifter and the old school look. If I take the easy way out, I'll get just a shifter ball, but the problem is none of the descriptions of the ***** I've seen states anything about a shift boot retainer or a spacer so that the ball is not right next to the leather boot. I want a little bit of space between the two. Do you guys have any info on shifter ***** and what they actually come with? Thanks again.
Old Nov 22, 2007 | 10:48 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: thewarmachine
I can custom make you a spacer for the leather boot.
The Shelby ball in MossMustangs catalog shows a similar spacer.
The descriptions on shifter ***** is lacking everywhere I see
them for sale. Its a hit or miss at the best as to whats actually included.
[IMG]local://upfiles/69445/893B118A9C94487382B7BF22BC866F83.jpg[/IMG]
Old Nov 22, 2007 | 10:52 AM
thewarmachine
Thanks, 157db. I'll keep you in mind if I go that route.
Old Nov 22, 2007 | 10:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
In fact if the new"shifter stick"you get hasS19712mm x 1.25 threads,
Istill have the first prototype I made and would not have to make one.
Old Nov 23, 2007 | 10:17 PM
2pistols's Avatar
2pistols
We just installed a triax in a friends 89 , he had a s197 **** installed on the stock I talked him into getting a b&m t-handle, same prob the threads didnt match but a quick run tthu with the appropriate tap hooked it up , handle and the nut, find a tap and try it on the ****, good luck
Old Nov 23, 2007 | 10:34 PM
thewarmachine
Actually I have just placed an order for this one in black. http://www.shop.hms-store.com/produc...;categoryId=22
I ordered the one for the 79-04 model Mustang, so it should fit my tri-ax handle.
carid
Jul 8, 2016 09:55 AM
Sep 10, 2015 08:39 PM
Sep 10, 2015 11:46 AM
Other Professional Racing
Sep 10, 2015 11:41 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
