Roush UDP problem
Old Nov 24, 2007 | 04:42 PM
gunnerdog's Avatar
gunnerdog
Default Roush UDP problem
After installing my Roush underdrive pulleys I have belt noise and have been getting misfires trouble codes. Is the torque off? Or is the pulley bad? Please help.
Old Nov 24, 2007 | 04:45 PM
DeStonn's Avatar
DeStonn
Default RE: Roush UDP problem
Might be the belt...but this is purely a guess
Old Nov 24, 2007 | 04:51 PM
gunnerdog's Avatar
gunnerdog
Its an 2007 with 23,000 miles on it. No problems with the belt before the install. Can a bad harmonic balancer cause misfires?
Old Nov 25, 2007 | 04:24 PM
gunnerdog's Avatar
gunnerdog
Any last bit of advice before I pull these off and my wife ends mustang mods?
Old Nov 25, 2007 | 05:13 PM
white531's Avatar
white531
There could be a bolt hitting the upper pulley.It may need to be cut off because the pulley is bigger.Look at about 1 oclock. You mayalso see a shiney mark around the back of the pulley.
Old Nov 25, 2007 | 05:50 PM
Boss919's Avatar
Boss919
It sounds like your damper might not be installed all the way. That would make the pulse wheel loose causing your miss fire.
warwickbass
Sep 20, 2015 04:51 PM
jim2015
Sep 14, 2015 08:09 PM
MasterLanMan
Sep 13, 2015 08:21 PM
TimeLord101
Sep 4, 2015 09:27 AM
