TPMS QUESTION
Old Dec 19, 2007 | 10:53 AM
onederful100's Avatar
onederful100
Default RE: TPMS QUESTION
ORIGINAL: nobrakes
What exactly does the TPMS light look like and where is it on the main gauge system?
on the left side of steering wheel, where the warning lamps are located there comes a flashing light that looks like an exclamation point (!). this flashes for about 15-20 seconds then turns off. also where the digital odometer is there are words that say TPMS fault and this stays on until you press reset to the right of the odometer. you must press reset every time you start the car. i do this bc its cheaper
Old Dec 19, 2007 | 10:55 AM
onederful100
this weekend i'm gonna remove the TPMS from the old rims, and put them inside the spare tire and see how this works.
Old Dec 19, 2007 | 11:06 AM
grabberorange1's Avatar
grabberorange1
ORIGINAL: one eyed *****
what happens when the tires with bands are removed from the car entirly?
i only get the flashing light every once in a while,seems like if the tires didnt have bands in them i would get the flashing light all the time.
Do you still have the original tires in your garage or close to where you park your car? I've had my 20's on for 6 months, with the stock tires in the garage and only after traveling 45 miles from home did the sensor ever go off. I just dismounted my stock wheels and took out the sensors to sell them, and now have to reset everytime I start it. I will put them in my new wheels because now the flat tire light won't go out even after reset.
Old Dec 19, 2007 | 05:20 PM
Sprzout's Avatar
Sprzout
This is probably going to sound like a dumb question, but...
For those of you with 07+, how do you handle putting on different wheels/tires when you go to the dragstrip? Do you just reset the light or let it freak out while you're driving it? Or do you put sensors on the new wheels and have them calibrated? Just curious...
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
