Will Baer Rotors Work On GT500 Brembo Brake Kit?
Old Nov 25, 2007 | 03:29 PM
brian70068's Avatar
brian70068
Default Will Baer Rotors Work On GT500 Brembo Brake Kit?
Will Baer Rotors Work On GT500 Brembo Brake Kit? I am getting the GT500 Brembo Brakes for my GT and Baer Rear Brake kit and i was wondering if Baer front rotors willwork on the GT500 calipers.
Old Nov 25, 2007 | 04:07 PM
marcuskeeler's Avatar
marcuskeeler
Default RE: Will Baer Rotors Work On GT500 Brembo Brake Kit?
Is there a reason you don't like the rotors which come with the GT500 setup? If you want cross drilledrotors you could get the Brembo Gran Turismo setup, basically the GT500 setup but with crossdrilled rotors and red calipers.
Got to be cheaper than tossing the GT500 rotors away right?
Old Nov 25, 2007 | 04:18 PM
Skycam4's Avatar
Skycam4
No they won't work. If you look under my post I found a company manufacturing a set for the GT500 so get on the list. They were around $600 for all 4 drilled and coated. I want my just for look b/c I have the GT-40 wheels on my 500.
John
Old Nov 25, 2007 | 04:35 PM
brian70068's Avatar
brian70068
Is there a reason you don't like the rotors which come with the GT500 setup?i ordered the Brembos and decided to get some Rear Brakes to so i am getting the Baer Rear Brake kit and Baer front rotors.
Old Nov 25, 2007 | 04:42 PM
brian70068's Avatar
brian70068
ORIGINAL: Skycam4
John
thanks skycam4
Old Nov 25, 2007 | 04:43 PM
CataclysmGT's Avatar
CataclysmGT
I'd suggest getting Brembo for the rear as well then. The Baer rear disks are 14", and Brembo states online that their rear kit is not increased in size, since that may upset brake balance.
Brembo also has a 6 piston kit out as well..........something I am greatly considering.
Old Nov 25, 2007 | 04:47 PM
brian70068's Avatar
brian70068
i just wanted to get the Baer Rear Brake kit and some Baer front rotors for my Brembos
Old Nov 25, 2007 | 04:50 PM
brian70068's Avatar
brian70068
ok give somting that will match Brembo cross drilledrotors
Old Nov 25, 2007 | 05:25 PM
brian70068's Avatar
brian70068
i decided to send the Brembos back and just get the Baer Extremes for like $2700 so i am getting the front and no rear brakes for now LOL [:@]
Old Nov 25, 2007 | 05:30 PM
brian70068's Avatar
brian70068
