Problems with my Procharger
Old Nov 30, 2007 | 12:52 AM
pLaGuIeNtO's Avatar
pLaGuIeNtO
Default Problems with my Procharger
Hello guys, probably some remember me, two months ago I got into this car accident that sent me to the hospital and my car to the shop, thanks to this lady that crossed in a red light, well, after I received my car back I wanted to do something different, leave it completely stock in the outside and work in the engine, after thinking about it for a couple of days I decided to go for it and well, here is the result :
Mustang GT 07 Automatic :
-JBA LT
-O/R Xpipe
-Ati Procharger 10psi (12psi pulley on its way)
-Tokico D-specs (going to install them this weekend)
-Eibach Pro Kit Springs (going to install this weekend)
-3.73 gears
I just received my car back today, while I was testing it tonight I had the next problems : It is really hard for me to make my car run, sometimes when I step in the gas I can feel the procharger kicking in but sometimes I cant, when I floor it the car feels like if it didnt had power at all then it starts moving slowly, for some strange reason my car stops making power around 75-85 miles, it just stops there even if Im flooring the pedal, someone with a procharger in automatic that could help me here?
Oh, before I forgot, I still have the stock exhaust, maybe is just making too much preasure and is getting stocked back there, what you guys think!?
Thanks in advance!!!
Old Nov 30, 2007 | 01:04 AM
A1SALEEN's Avatar
A1SALEEN
Default RE: Problems with my Procharger
it sounds kinda like a fuel issue .... or a tune issue.... also double check you tubing make sure it's all really tight if you have a leak it could cause that
Old Nov 30, 2007 | 01:07 AM
pLaGuIeNtO's Avatar
pLaGuIeNtO
Thanks man, I will it take it back to the garage where they installed it, I will let you know what happend.
Old Nov 30, 2007 | 03:27 AM
moosestang's Avatar
moosestang
You should atleast have a boost gauge so you can see if you are making boost. It's not your exhaust, that's for sure.
Old Nov 30, 2007 | 04:04 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
maybe a tune or belt slippage? Gauges will help but the tuner that tuned it will be able to test drive and figure it out! Car lloks great and the S/c is very nice!
Old Nov 30, 2007 | 04:06 AM
marcuskeeler's Avatar
marcuskeeler
Belt slip [?]
Can you put a carriage return between your pictures, the page layout is screwed up..............
Old Nov 30, 2007 | 04:09 AM
mygt500's Avatar
mygt500
just a guess? Marcus check out the glass top thread on the first page of the 2005+ section
Old Nov 30, 2007 | 08:19 AM
VaBeachMustang's Avatar
VaBeachMustang
What size injectors are you using?
Old Nov 30, 2007 | 12:33 PM
SCCAGT's Avatar
SCCAGT
Your problem is the tune itself. I'm surprised they are still sending out the auto kits without the correct tune. My car was used to get the bugs out for the auto tune. Call ProCharger up and see if they can email you a new tune. Or find a tuning shop that has the Predator software. I will pm you my tune. It wont be totally correct for your car but will at least make it drive right.
Dont worry, You didnt do anything wrong. Its easily fixed.
Old Nov 30, 2007 | 12:47 PM
Dex's Avatar
Dex
whats your mafia set at?
