Sequential Tailights
Old Dec 1, 2007 | 03:24 PM
  #21
theresa's Avatar
theresa
Default RE: Sequential Tailights
I have the chase lights, love love love 'em.
Old Dec 1, 2007 | 04:04 PM
  #22
Daniel60's Avatar
Daniel60
I got mine from here. They were super affordable however I had someone else install them. There is some splicing. http://www.mustangtaillightsequencers.com/
Personally I think they blink too fast but I still like them. Chaser or whatever I haven't a clue what these are. Will someone explain the different types?
Old Dec 1, 2007 | 04:14 PM
  #23
Fallout's Avatar
Fallout
i believe the onyl difference between regular seqential and chaser, is if you look on the one you posted, each one lights up and stays lit until all 3 are on, then all 3 go out at once and it restarts. chaser i think come on then go off the second the next one comes on, and theres no stopping between the sequence, so theres always one lit up..i could be wrong but the clip i saw made it seem that was the only difference
Old Dec 1, 2007 | 04:19 PM
  #24
xtremesaleen's Avatar
xtremesaleen
i was curious what the difference was so, here a vid on what chasers look like...
http://vids.myspace.com/index.cfm?fu...deoID=19163772
Old Dec 1, 2007 | 06:28 PM
  #25
clustersnarf's Avatar
clustersnarf
Here's video of mine on the old 05GT
http://networkgeek.org/~djpowell/stanglights/
I moved the harnesses from the 05 to the 07 and it worked fine. I heard later that that was hit or miss. I still get looks, its pretty funny to see kids in the passenger seat pointing at it while their mom is stopped behind me in the soccermomvan. Luckily I went with the webelectric ones and when I totaled the 05 I had them pull the harnesses out and gave them the OEM ones.
Something to think of when you do this mod. its more expensive to keep the original ones if you get pre-built ones, BUT , if you lose the car, thats cash gone.
Old Dec 1, 2007 | 06:31 PM
  #26
Thurman's Avatar
Thurman
This is one of those mods that I kinda like, but it seems their is always something else that comes up to take its place.
Old Dec 1, 2007 | 06:39 PM
  #27
06GTGIRL's Avatar
06GTGIRL
Yep, I have them and I love them. Get peopleasking me all the time. So far I have not seen any other mustangs in our town with them on.I got mine from CDC and I put them on myself.
Old Dec 1, 2007 | 06:46 PM
  #28
owero01's Avatar
owero01
Have them, love them, get complements all of the time. I have the CDC plug and play. Took 30 minutes with kids asking questions.
Old Dec 1, 2007 | 07:56 PM
  #29
cavediver's Avatar
cavediver
I have:
www.webelectricproducts.com
They were true 'plug and play', no splicing, high quality and they arrived 2 days after I ordered them. They look great and I get lots of compliments on them.
Old Dec 1, 2007 | 08:17 PM
  #30
wthalliii's Avatar
wthalliii
I have the meter4it kit. http://meter4it.com It does require cutting and splicing wires, but it uses squeeze on connectors. You could solder it as someone said they did, but it's not necessary. And, in addition to doing the chase sequence, it will also do the normal sequential sequence, and also easily switch back to the factory mode, I.E., just flash the lights. It flashes all 3 lights in the factory mode, though, unlike the original signals, which only flash the outside two. So if you had trouble with state inspection, for instance, you could just switch it back to factory mode. And it only takes a couple of minutes to switch it to another mode. You just move a jumper on the electronics box and then press a button for a few seconds with the turn signal on. I've never had mine out of the chase mode, though. It really looks cool.
Just my $.02 worth. $.02 isn't worth much any more, though.
