Panhard Bar
Old Dec 2, 2007 | 11:33 PM
rford426's Avatar
rford426
Default Panhard Bar
Anyone have this?? could you tell a differnce at all??
Old Dec 2, 2007 | 11:48 PM
thewarmachine's Avatar
thewarmachine
Default RE: Panhard Bar
I got one when I installed my Roush rear springs. If you lower your car, you will need an adjustable Panhard rod to get your rear tires centered under the car.
Old Dec 2, 2007 | 11:53 PM
ohnoesaz's Avatar
ohnoesaz
I got a panhard and panhard brace. The stock panhard is hollow and thin, its almost sad... Get it. Also, I think the most noticeable difference was anti-sway bars. People say lower control arms are the best part to replace, but I didnt really notice a difference when I did mine. Still had major wheel hop.
Do the panhard and panhard brace. Its worth it.
Old Dec 2, 2007 | 11:59 PM
teksp0rt's Avatar
teksp0rt
ORIGINAL: thewarmachine
I thought it was used for more aggressive drops. The Roush rear springs only lower the rear by 1" so I don't know if it made too much of a difference. Cound you not get the car aligned properly?
Anyway, I lowered my car with the Eibach Prokit (1.3" Front / 1.5" Rear) and I don't think I will need a panhard bar. It is still not that aggressive of a drop but definately noticable. Everything is set up and aligned nicely. I also have the Eibach front and rear sway bars as ohnoesaz mentioned. The front sway bar has 3 adjustment settings depending upon what you are looking to accomplish. I installed mine using the middle adjustment. In any event, I noticed huge differences in the responsiveness of the car after changing the sway bars.
Old Dec 3, 2007 | 12:06 AM
thewarmachine
I was running 295's out back at the time, and I did notice the left tire sticking out farther after the lowering.
Old Dec 3, 2007 | 12:12 AM
rmays06's Avatar
rmays06
Didn't need one when I lowered the car either, I had 1/8" to the right which is standard from the factory in case you fall asleep at the wee it will pull you to the side.
The stock panhard is cheap and heavy, if you into twisty driving its a must.
Old Dec 3, 2007 | 12:15 AM
alloutt's Avatar
alloutt
It is a good improvement to get.
Old Dec 3, 2007 | 02:09 AM
Caution's Avatar
Caution
+1 -- you'll notice the difference when you look at your stang and see it centered
Old Dec 3, 2007 | 08:17 AM
Thurman's Avatar
Thurman
I'l be ordering mine in the soring.
Old Dec 3, 2007 | 08:28 AM
Argonaut's Avatar
Argonaut
ORIGINAL: rmays06
Interesting that you say the factory setting has the rear axle 1/8" to the right. My experience is different. On 07 GT - didn't notice a difference stock but once I put 9" DDs on it the left rear was clearly closer to the fender lip than the right. So I'd say, if anything, mine came from the factory set up to the left. Weird.
