Headlight vent location
Old Dec 4, 2007 | 03:15 AM
surf808's Avatar
surf808
Default Headlight vent location
Hey. I was wondering if anyone knew where the headlight vent is. I have some condensation and want to check if the vent is plugged or something. I really don't want to have to take it to the dealer to fix and if there is something simple that I can do all the better.
Thanks.
Old Dec 4, 2007 | 03:17 AM
06jalmustang's Avatar
06jalmustang
Default RE: Headlight vent location
I dont think they are vented. Pretty sure they are a sealed unit.
Old Dec 4, 2007 | 06:44 AM
BeeStang's Avatar
BeeStang
Take it to the dealer, you have a seal breach somewhere. It should be covered under warranty unless you changed something like a high wattage bulb that melted the seal or the bulb opening somehow.
Old Dec 4, 2007 | 07:17 PM
surf808's Avatar
surf808
I was afraid I would have to take it to the dealer. I have the silverstars in there but I don't think they caused the problem.
Thanks anyway.
Old Dec 4, 2007 | 09:04 PM
Bluestar's Avatar
Bluestar
Check to see if you turned the Silverstars all the way to tight. It's possible to put one in and not tighten it, allowing air in there, which could be a cause of condensation.
Old Dec 4, 2007 | 09:44 PM
surf808's Avatar
surf808
The light bulb is in there tight.
Old Dec 4, 2007 | 09:57 PM
rford426's Avatar
rford426
put the oem bulbs in and take it in...
Old Dec 4, 2007 | 10:00 PM
blackout's Avatar
blackout
It will not be covered under warranty if you don't replace the stock bulbs before going to the dealership. So switch them back and they might just give you a new headlamp assay...
-Jeff
Old Dec 4, 2007 | 11:35 PM
surf808's Avatar
surf808
Yeah will do. Thanks guys.
Old Dec 4, 2007 | 11:49 PM
Bluestar's Avatar
Bluestar
NEVER MIND
mrtrodonet
Sep 19, 2020 03:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Drastang
Sep 29, 2015 03:31 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
tmdm
Sep 4, 2015 06:45 PM
