Side Scoops
Old Dec 12, 2007 | 11:04 AM
BadS197's Avatar
BadS197
Banned
Default RE: Side Scoops
The aftermarket scoops are not identical but they are pretty close, the tape is not visible at all once installed. Here are some pics with measurements to give you a better idea...
Old Dec 12, 2007 | 11:38 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Nuke
DO NOT use 70% alcohol or even 90%. The other ingredients in them are enough to contaminate the surface and prevent the best possible adhesion. Since I couldn't find 100% alcohol, I purchased a solvent at a local auto parts store specifically designed to strip the wax and oils off the surface without damaging the paint. Worked like a charm on the side scoops plus I used it on the quarter side window glass when I installed my louvers. Ditto on the temperatures and other "stuff" mentioned above except the addition of allowing everything to cure for 24 hours afterinstallation of the scoopsbefore driving.
Use 3M Adhesion Promoter 4298 on the scoops.
[IMG]local://upfiles/69445/D40BF39F66EF4D34B941D3475B91118C.jpg[/IMG]
Old Dec 12, 2007 | 11:54 AM
brendend's Avatar
brendend
i used 90% it took everything off. i had to was the entire car and wax around the scoops
Old Dec 12, 2007 | 02:15 PM
kenthicken's Avatar
kenthicken
I installed the factory GT/CS scoops -- without the screws into the sheetmetal. The screw tabs on the scoops are easily removable. Just be sure to prep the surface correctly and use ONLY 3M double-sided tape for the install.
I actually bought my side scoops one at a time via eBay (left side = $30, right side = $40) and saved a ton of money. If you can keep your eyes open and wait a while, this is the way to do it!
Old Dec 12, 2007 | 03:38 PM
tungstenstang's Avatar
tungstenstang
how they holdin up? i love the look of the gt/cs scoops and the street sceens are cool too.
Old Dec 12, 2007 | 04:15 PM
bad1032's Avatar
bad1032
I bought the ford gt/cs scoops and installed them with no problem, used the prep pad supplied with the kit,looks good. glad i went that route,
Old Dec 12, 2007 | 05:13 PM
kenthicken's Avatar
kenthicken
Holding up fine. I assume the reason Ford put the screws in the scoops was because they did not want the risk of the scoop coming off (and thus, warranty issues), and did it as an extra means of security. It's probably not necessary, seeing as every other side scoop does not require you to drill holes.
Old Dec 12, 2007 | 09:48 PM
Aziraphale's Avatar
Aziraphale
I'm getting the ford ones also, I like the look of them the best. Partscheap has them the cheapest I've found and as a reference, I had 2 body shops (one ford, one recommended by a friend) quote me $100 to paint both.
Old Dec 13, 2007 | 03:40 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I agree and surface prep is everything!!!!!!!!!!!!
ORIGINAL: Nuke
Ditto on the aftermarket and the 3M tape. I have a set prepainted from hubcapsplus.com and they've survived over 7000 miles and are solid as a rock. The paint was a perfect match, too, so consider aftermarket. With the tape, it's all in the surface preperation and application temperature that will determine how well they stay in place.
Old Dec 13, 2007 | 09:08 AM
ohnoesaz's Avatar
ohnoesaz
$239 off Ebay, includes paint and shipping. These are the cali special side scoops so they have clips, not just double sided tape.
EDIT: Maybe they dont have clips... anyways they work
http://cgi.ebay.com/ebaymotors/05-06...spagenameZWDVW
I've bought several times from this seller, not side scoops, but hes trustworthy.
