GT side skirts
Old Dec 12, 2007 | 02:33 PM
kngdaka's Avatar
kngdaka
Default GT side skirts
I've tracked down a pair of GT take off side skirts, and I just had a quick question before I pull the trigger.
The ones on my car are attached with plastic pegs down the underside of the car. How do I remove these to take the skirt off? After I get the old one off, do I reuse these pegs, or do I need new ones? How do I re-attach the GT takeoff?
Thanks
Old Dec 12, 2007 | 03:29 PM
Stang Girl13's Avatar
Stang Girl13
Default RE: GT side skirts
You can reuse the old ones, but I would check to see if the new ones come with it. They can get damaged easy while removing the old ones. I think there is a sticky thread on how to install rockers.
Old Dec 12, 2007 | 03:41 PM
partsbill's Avatar
partsbill
the ford part number for the push pins is W710532-S300 and they only retail for
$1.51 each, I keep extras on hand because every time I change my oil my rockers drag as I drive off the lift and I end up ripping 1 or 2 out.
Old Dec 12, 2007 | 03:46 PM
kngdaka's Avatar
kngdaka
so you just rip the old ones out, get all of them off, and the panel should come right off?
And then I'd get new ones, put up the new panel, and then use a rubber hammer to hammer them in?
I can't find that sticky. But if this is all, I can handle that.
Old Dec 12, 2007 | 03:57 PM
kngdaka's Avatar
kngdaka
Nevermind, I found it!
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
Drastang
Sep 29, 2015 03:31 PM
