HIDS???
Old Dec 14, 2007 | 02:32 AM
surf808's Avatar
surf808
Default RE: HIDS???
I bought my kit from Retro-Solutions. I have yet to install it due to my headlight lens having water inside and hoping the dealer will fix it. There is a thread about the kit and it seems like the best deal around.
https://mustangforums.com/m_4190083/tm.htm
Old Dec 14, 2007 | 05:05 AM
olvanish's Avatar
olvanish
Default RE: HIDS???
ORIGINAL: gothamems
Dude save yourself alot of aggrivation and money, and replace your stock head lamps with 8500K-9000K bulbs. My 2008 came through with HIDs but the fogs, well looked like a$$, very yellow in comparison, I swaped the fog lamps out with 8500Ks, and they look dam close. BTW, 8500K is a spectrum value, the lower the number the more yellow it looks, the hiher the number the more blue it looks, 8500K is a crisp HID white.
Actually 6000k is white, 8 is blue, 10 is dark blue and 12 is purple. If it's 8500k and it's white then it's not 8500k. But I agree with the statement above though, don't get yourself HID's, too much money, a little headache, and too little difference between them and regular Silverstar Ultras... not worth it I'd say (pls note, it's coming from someone who has them)
Old Dec 14, 2007 | 06:55 AM
Full Throttle's Avatar
Full Throttle
Default RE: HIDS???
ORIGINAL: olvanish
ORIGINAL: gothamems
The thing is the Silverstar Ultras last about 4-6 months, I'm not sure how that compares to the HIDs and how long do they last?
Old Dec 14, 2007 | 08:16 AM
metroplex's Avatar
metroplex
Default RE: HIDS???
Most aftermarket HID's utilize a re-based D2R capsule (2nd generation, reflector based HID) and use ballasts that are Phillips knock-offs. These ballasts have a fake plastic cap in-between the high-voltage output and the low-voltage input leads. They also have a built-in ignitor negating the need to mount separate ignitors.
Here are some interesting tid-bits.
OEM's generally equip their cars with 4100K HID's, and most commonly use D2R, D2S, and even D1S capsules. The "S" stands for "shielding" typically used in projector lamps. OEM's sell 5000K HIDs as replacements so the color temperature matches the other HID. They don't tell you to replace both at the same time because it can cost up to $300 per capsule!
The "S" HID capsules produce 3200 lumens and are rated for 2500 hours. Between 2500-5000 hours of operation, the color temperature rises until ti becomes pink. The "R" HID capsules are rated for 2800 lumens, same lifespan.
The 2008 Mustang has optional HIDs which use D3R capsules. D3 is 3rd generation. 3rd and 4th gen HIDs are mercury-free and produce the same amount of light as their 1st and 2nd gen counterparts.
I am using 4100K VVME BI-xenon HIDs in my Crown Vic and find that these lights are significantly brighter than halogens, but will easily exploit poorly designed reflectors and lamp assemblies. I feel that our S197 GT's have very good headlamps so HID retrofits will work nicely with a very sharp cut-off and less light leakage.
4100ks look white with a very slight tint of blue. I do not recommend 5000K or higher because it will be too blue and actually produce less light. Daylight is supposed to be about 5800K, but I'm telling you that 4100K looks white with a slight tint of blue. I can actually see the solar-tinting on my windshield turn the white light a slight tint of green/blue. 5000K-6000K is going to look more blue than white, so to each his/her own.
In comparison, the H13/9008 Halogens used in the S197s produce 1000 lumens in low beam and 1300 lumens in high beam. So we're looking at roughly 3 times more light and only 2-3 times longer lifespan with HIDs.
Retrofitting the 2008 OEM HIDs into a 2005-2007 would be the best way to go, followed by installing a 4100K HID retrofit for the foglamps.
Old Dec 14, 2007 | 08:17 AM
d_ames117's Avatar
d_ames117
Default RE: HIDS???
HID's will last for thousands of hours.
Dustin
Old Dec 14, 2007 | 08:20 AM
metroplex's Avatar
metroplex
Default RE: HIDS???
D1, D2, D3, and D4 are supposed to be rated for 2000-2500+ hours. By 5000 hours they may start to turn pink.
9008/H13 halogens are rated for 1000 hours low beam.
Old Dec 14, 2007 | 11:16 AM
rford426's Avatar
rford426
Default RE: HIDS???
ORIGINAL: metroplex
DANG you know whats up ahha....id like to get the ford ones but i gurantee they will be outreagous if i can get the ones in tthe link for 205 shipped ill probly do it and see how they turn out. A couple of my friends have them but not in mustangs and they haven't had any problems and they look good also.
Old Dec 14, 2007 | 03:41 PM
kdrshocker's Avatar
kdrshocker
Default RE: HIDS???
https://mustangforums.com/m_4236581/tm.htm
can't get much cheaper than that and they are decent quality.
Old Dec 14, 2007 | 03:54 PM
olvanish's Avatar
olvanish
Default RE: HIDS???
ORIGINAL: Full Throttle
ORIGINAL: olvanish
ORIGINAL: gothamems
You talking about regular silverstars (they don't last that long) or about the actual ultras that just barely came out (the ones that come in LIGHT, not dark blue packaging)? I heard those were pretty good. We got them in at Auto Zone over a year ago and so far no complaints, regular silverstars do get a lot of crap said about them though lol Only thing is I'm not sure if they make H13, Auto Zone doesn't have those in stock, but it might be available for special order
Diode Dynamics
28
May 26, 2022 12:02 PM
kawiguy827
Sep 22, 2015 10:52 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
inyadreems
Aug 21, 2015 09:10 AM
stangmods.com
121
Mar 9, 2009 01:18 PM
