Changing automatic Trans fluid
Old Dec 14, 2007 | 01:23 PM
sevenleaf's Avatar
sevenleaf
Default Changing automatic Trans fluid
For anyone who changed their automatic transmission fluid did you just drop the pan then empty it to drain it? I know NAPA has a pump for $20 to pump the fluid back in.
Old Dec 14, 2007 | 01:55 PM
Nuke's Avatar
Nuke
Default RE: Changing automatic Trans fluid
Just dropping the pan and draining will only get about 1/3 or less of the fluid out of the tranny. It should be power flushed but there are issues doing that on high mileage trannys. Otherwise, a power flush by a reputable shop is the way to go.
Old Dec 14, 2007 | 02:15 PM
99flhr's Avatar
99flhr
ORIGINAL: sevenleaf
Dropping the pandoes however allow you to change the filter.
mungodrums
Oct 7, 2015 04:01 AM
97SN95GT
Sep 13, 2015 09:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
