2008 Exhaust?
I bought a SLP LM kit off of a member, recieved it today. However will this kit bolt up to my 2008? I thought I saw some where that you need different hangers. The drivers side is pretty close but the passenger side is pretty far off. I need some quick advice.
i have after market borlas on my '08. hung without issue. well, had to bend some little metal flap that was hanging down under the car that cause a slight rattle sound. Other than that, nothing special.
The issue was for some 2007 Mustangs...and maybe 2008 also. They had replaced the brackets that hold the mufflers with rubber ones, and they did not work with some aftermarket mufflers. American Muscle sells the metal brackets if you need them.
I think all of this is correct.
Depending how far off they are, if you haven't already done so loosen the clamps up in the middle of the car, that hold the pipes between the H-pipe and the axle-backs. That can give you some adjustment.
Sep 30, 2015 12:39 PM
junior04
Sep 28, 2015 10:53 AM
Sep 24, 2015 09:18 PM
