Before I go crazy...
Old Dec 15, 2007 | 11:39 PM
noober's Avatar
noober
Default Before I go crazy...
Ok I KNOW that this has been brought up in the past... (why else would have I have the urge or half-way knowhow on what to do..)
But I don't know which wire I need to splice in my wire bundle near the kick panel on the passenger side to install the trunk release switch.
I've been told it's white with a pink line and I've been told it's white and I've been told it's pink, so I found one that looked like that, and that only controlled the High beams staying on. Can someone SNAPSHOT or TAKE A PICTURE the actual line or send me an alternate and less intensive way to splice this line in to finally work? I'm going nuts here and google yields nothing friendly.
[sm=headbang.gif][sm=helpout.gif][sm=smiley35.gif][sm=ttiwwp.gif]
Any help is more than appreciated.
Old Dec 15, 2007 | 11:46 PM
tungstenstang's Avatar
tungstenstang
Default RE: Before I go crazy...
you ask for the most bizzar stuff, why cant you use you trunk poper on the key fog?
Old Dec 15, 2007 | 11:53 PM
noober's Avatar
noober
I ask for nothing odd! ^_^ Just a million dollars and a mansion on the mood.
And I don't wanna keep flipping for the trunk button on the FOB. I have a paranoia that I'm gonna be dead on battery with the FOB and I'm gonna desperately going to need a trunk release some time in the future.
Old Dec 15, 2007 | 11:58 PM
howarmat's Avatar
howarmat
s197 Junkie
http://www.cherod.com/mustang/HowTo/TrunkRelease.htm
Old Dec 16, 2007 | 12:01 AM
noober's Avatar
noober
I have that printed and followed it till the point where it described the wire and the author tried his hardest to take a pic of the wire. The only issue is that the picture is HORRIBLY fuzzy, and that's where I'm stuck. Till then, I have a nicely placed button that pretty flush with a grounded wire in the back and a loose hanging wire waiting to be merged with another wire.
What is that other wire, or which one is it?
Old Dec 16, 2007 | 12:47 AM
rford426's Avatar
rford426
i might do that but im not a huge fan of tacky toggle switches all over the place....
Old Dec 16, 2007 | 01:41 AM
mcgyvertech's Avatar
mcgyvertech
Do what I did, find the white wire w/ the pink stripe. Use a straight pin and a clip lead (wire w/ alligator clips on both ends) push the straight pin through the insulation and ground the alligator clip. The trunk should pop; there's only ONE white wire with a pink stripe, i spent fifteen minutes sorting through the wires... there's only one.
good luck
Old Dec 16, 2007 | 09:19 AM
odiaz's Avatar
odiaz
Sorry Noober, I took that picture and I can't get my camera to focus that close to the wires. I guess I'm going to need a macro lens.
I had the same problem finding the wires. I ultimately gave up and went to the trunk, popped off the plastic cover over the lock assembly and took a look at the wires. I think Ford changed the color of the wires at some point during production.
To verify I had the right wire, I used a pin with an aligator clip just like McGyvertech recommended.
By the way, the choice of button makes a big difference also. Initially, I uised a Radioshack momentary contact shwitch. This type of switch makes contact as soon as the button is pressed. The problem with this is that the lightest tap on the glove compartment door would open the trunk. I played with rubber stoppers to stiffen the door but if you pushed hard enough on the corner of the glove compartment, the trunk woul pop open.
Eventually I bought a glove compartment switch from an older mustang. This works much better because the switch does not make contact until it is at the very end of its travel. Now, there is no way to accidntally open the trunk.
Old Dec 16, 2007 | 09:29 AM
qwikcobra's Avatar
qwikcobra
I couldn't find a white wire either, so I used the pink/orange and used anopen fuse slot to power it through the switch. I intercepted the pk/or in the passenger door sill area.
Old Dec 16, 2007 | 10:42 AM
qwikcobra's Avatar
qwikcobra
This is probably the same switch odiazused I like the OE look myself.
