Why me!!!! NEED HELP!!
Old Dec 19, 2007 | 12:52 PM
Ortoch's Avatar
Ortoch
Default RE: Why me!!!! NEED HELP!!
ORIGINAL: Bluestar
Is this a typo, or are you telling us that you got 254 RWHP with a Supercharger + the mods you listed. A run of the mill Stocker puts down an average of 262 RWHP. WTF ??????
i've never seen a 6 banger put out 262rwhp... you must tell me ur secrets
Old Dec 19, 2007 | 12:53 PM
Black Mamba GTT's Avatar
Black Mamba GTT
hahaha
Old Dec 19, 2007 | 01:27 PM
99flhr's Avatar
99flhr
I`m not putting anybody down but a specific output of 1.09 hp per c.i.d. is not impressive with 10psi of boost. Is this average? A stock 281 with a rwhp of 265 would be 1.06
EDIT: Fixed your quote - 28HopUp
Old Dec 19, 2007 | 01:34 PM
GT Bob's Avatar
GT Bob
266 with 10 pounds of boost is very low... Get rid of the plasma booster. I've never seen a good word written about them. Get yourself some stock style copper plugs, one heat range colder than stock, and I'd consider even putting most of the ignition as far back to stock as you can and start from there. NExt, I would look at your tune.. What kind of AFR's are you getting?
Old Dec 19, 2007 | 01:38 PM
Black Mamba GTT
I have got good air fuel ratio they are about the same but I am not sure what exactly what it is. So I should get rid of the Plasma booster?
Old Dec 19, 2007 | 02:32 PM
Legion5's Avatar
Legion5
I don't know how the 20's play in but you should be making at least 290+hp at 10psi with full exhaust.
254 is way too low for a supercharged 6.
Old Dec 19, 2007 | 02:48 PM
howarmat's Avatar
howarmat
s197 Junkie
Ok the HO system is suppose to bump you up to 330 @ the crank - 18% losses gives you about 270 to the wheels, -10 loss for the 20s and it comes out to 260ish.....all of these would be on a dynojet....
so adding in the other mods and you on a mustang dyno...anywhere from 250-265 sounds about right actually for a MD
Old Dec 19, 2007 | 02:51 PM
Black Mamba GTT
That makes sense, but what about the 6s that have the same set up that are getting like 300 to the wheels? I guess most of them are manual and don't have 20's tho and have aluminum ds so I guess that would be right? Right?
Old Dec 19, 2007 | 03:48 PM
howarmat's Avatar
howarmat
s197 Junkie
take the 20s off, be a manual and through it on a dynojet and 300 is probably not out of the question
Old Dec 19, 2007 | 03:55 PM
28HopUp's Avatar
28HopUp
MF Administrator
I found the following information on the forums, which may be helpful to you:
Mustang Dyno # X 1.09 = DynoJet Dyno #
or
DynoJet Dyno # / 1.09 = Mustang Dyno #
I've seen conversion numbers as low as 7%, and as high as 11%, so take the above quote with a grain of salt...
