Nitrous for a 07
I had the ZEX kit on mine before my Kenne Bell. The kit is specific for the Stang. It works really well, but You would also need colder spark plugs and a Kenne Bell Boost-a-pump to go over 100HP shot. I also recommend a bottle heater and pressure switch for optimum results. PM me if you want any additional info. I also did some other stuff that really made it work well.
jerjan
The problem with power----------
If your engine makes big power, Your tires just slip.
If you get sticky tires, your clutch burns out.
If you get a clutch that doesn't burn out and grabs, then your drive shaft twists.
So you get a drive shaft that can hold big HP and your rear end breaks, usually axles. you get a "N" cast 9in and Detroit locker with 35 spline axles and you run over the big lump in the road that was your transmission. Now you spend your wife’s lunch money on a tricked out B&M C-4 .
And NO ONE will race you.
