My idle RPM seems too low. When I rev it a bit, after it comes back down, it sounds almost like it goes too low and almost shuts off. I have brenspeed's tunes with the SCT xcal2, is there a way to raise the idle RPM with it? Or would that not help (i.e. i have a different problem)?
The needle is below the 750 line but above the 500 line. It sounds fine if I leave it alone but if I rev it to like 1500-2000 RPMs and let it drop it drops way low (like it's gonna die) and then goes back up to idle.
You can increase the idle with the SCT2 in the optional parameters menu. Here's the B-speed turorial for accessing the menus (if the link doesn't work it's in the tech section of their site):
