O/R X PIPE
Old Jan 2, 2008 | 02:06 PM
rford426's Avatar
rford426
Default O/R X PIPE
So found a good deal on a pypes o/r x pipe locally and going to pick it up later on today...just wondering how hard the install is like how hard it is to cut the cats off and what tools will i need and if you guys have any tips for me
Old Jan 2, 2008 | 02:27 PM
blike's Avatar
blike
Default RE: O/R X PIPE
You shouldn't have to cut anything to get off the stock midpipe. Check out this guide for installing an O/R H pipe, same idea
https://mustangforums.com/m_3065202/tm.htm
Old Jan 2, 2008 | 02:58 PM
rford426's Avatar
rford426
ive seen that so its all the same???
Old Jan 2, 2008 | 03:02 PM
Caution's Avatar
Caution
It's O/R meaning that there are no cats at all... install is easy and should take just over an hour
Old Jan 2, 2008 | 03:07 PM
brad281's Avatar
brad281
No cutting at all. I installed my o/r h by myself. Spare yourself plenty of time for when you get a tight fit though. Hardest part was fitting onto the stock manifolds. Fitment with pypes isn't good, imo. Be ready to hammer into place. As for tips. A long extension bar and swivel head wrench to reach the manifold bolts.
Old Jan 2, 2008 | 03:09 PM
rford426's Avatar
rford426
ok thanks guys...you think 65 bucks is a good buy???
Old Jan 2, 2008 | 03:25 PM
Caution's Avatar
Caution
65 is cheap
Old Jan 2, 2008 | 04:16 PM
rford426's Avatar
rford426
will i have a check engine light on???
Old Jan 2, 2008 | 04:19 PM
Caution's Avatar
Caution
I did but I just turned off my rear o2 sensor
ORIGINAL: rford426
Old Jan 2, 2008 | 04:24 PM
DeStonn's Avatar
DeStonn
DO NOT cut the cats...the factory midpipe should unbolt and the new one should bolt right in its place. Make sure you keep your Cats because they are worth some cash and if you end up going back to stock or you need cats you will pay a pretty penny for replacements.
If you have an aftermarket tune the rear O2 sensors will be turned off.
Some people do not like the raspy sound the x-pipe gives off. If you go chambered mufflers it might not be so bad, but if you go with a set of straight through or 'race' exhaust you might regret it.
