A little shake
Old Jan 3, 2008 | 02:08 PM
d_ames117's Avatar
d_ames117
Default RE: A little shake
ORIGINAL: MrSandman
Well of course that's another explanation..
ORIGINAL: d_ames117
Slightly warped rotors.
The car shook because it was afraid that Chuck Norris was going to roundhouse kick it in the grill for speeding.
Old Jan 3, 2008 | 02:38 PM
Bluestar's Avatar
Bluestar
http://youtube.com/watch?v=UbhzTIMUFI4
Old Jan 3, 2008 | 06:15 PM
gnrpatience's Avatar
gnrpatience
If it is warped rotors what should i do to fix ?
Thanks
Old Jan 4, 2008 | 09:09 AM
d_ames117's Avatar
d_ames117
If it just shakes a little, I wouldn't worry about it. Otherwise, a new set of rotors or having the old ones machined flat (if possible) would do the trick. Does it shake anytime you hit the brakes? Only at high speed? When you push hard on the pedal? Do you feel the peddle undulate?
Dustin
Old Jan 4, 2008 | 09:28 AM
pascal's Avatar
pascal
S197 Section Modder-ator
"That's right man! Nobody f###s with the Jesus!"
John Turturo... The big Lebowski.
[quote]ORIGINAL: MrSandman
That's just Jesus telling you to slow it down on public roads. Perfectly normal.. but it's hard to ignore Jesus.. almost as hard as ignoring Chuck Norris.
http://www.chucknorrisfacts.com/
Old Jan 4, 2008 | 09:34 AM
RED121572's Avatar
RED121572
Worn or out of balance tires? Is there any snow stuck in the wheels?
Old Jan 4, 2008 | 09:40 AM
pascal's Avatar
pascal
Good place to look...
Lumpy tires too.
Slight misalignment. Happens more often than one think...
A little bump against the curb and it's off.
Old Jan 4, 2008 | 09:54 AM
gnrpatience
ORIGINAL: d_ames117
Dustin
It does not happen at anytime, yes only in high speed and im not pushing hard the pedal just lowering speed to take curve. I dont feel nothing wrong with the pedal.
Old Jan 4, 2008 | 11:34 AM
Caution's Avatar
Caution
I vote that you may have slightly warped rotors
Old Jan 4, 2008 | 11:57 AM
gnrpatience
So if it is the rotors what should i need to fix it ?
So in conclusion non of you after pushing the brake in high speed 100-120MPH feel nothing ?
Thanks
