dumb question about pinging..
Old Jan 5, 2008 | 06:51 PM
SonicBlue05GT's Avatar
SonicBlue05GT
Default dumb question about pinging..
I fill my car up with 87 and it pings like crazy at WOT. I use 89 and it goes away.
my 2001 GT did the same thing..
- is it doing it because the gas sucks? (which I wouldn't doubt down here)
- is there a way to fix it other than just using a higher octane? (a tune or something?)
Old Jan 5, 2008 | 07:01 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: dumb question about pinging..
yes you can get a tune for the higher gas level for better performance....the manual also states you might have pinging with the lower oct and need to use higher oct.
Old Jan 5, 2008 | 08:17 PM
Argonaut's Avatar
Argonaut
You might want to try running a can of Seafoam thru it. Carbon buildup can cause this.
Old Jan 5, 2008 | 09:21 PM
YellowFlame's Avatar
YellowFlame
You might just be shifting too early and getting on it.
If it pings - downshift.
Old Jan 5, 2008 | 09:51 PM
my first mustang's Avatar
my first mustang
Run the 89 octane and don't worry about it.
Old Jan 5, 2008 | 09:59 PM
SonicBlue05GT
ORIGINAL: YellowFlame
i'm not shifting early, but it doesn't seem like it should do it ever.
Old Jan 5, 2008 | 10:06 PM
YellowFlame
ORIGINAL: SonicBlue05GT
EVER? Like if you shift into 5th at 20 mph and hammer onit, you think it shouldn't ping?
But, the car is designed to run on regular, if it pings during normal driving with regular gas, you either have some bad gas (that crap in the midwest with the corn alcohol in it will make it ping like crazy) or it's time for a tuneup, or there's something wrong with the timing.
Old Jan 5, 2008 | 10:09 PM
howarmat's Avatar
howarmat
s197 Junkie
if you drop in into 5th going 20 it will lug......not rev to high rpms......you can floor it and it just takes off slowly....i am lost why this would ping
Old Jan 5, 2008 | 10:14 PM
SonicBlue05GT
yeah i can understand it bogging down and sounding 'rough', but not pinging.
anyway, mine does it at WOT regardless of gear/speed.
i'll just keep using 89. must be nasty gas down here [:'(]
Old Jan 6, 2008 | 08:19 AM
joemagna's Avatar
joemagna
I dont think it should ping.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
