Overspeed warning?
Old Jan 10, 2008 | 01:33 PM
bhaz413's Avatar
bhaz413
Default Overspeed warning?
So just got the car back from the shop after getting a new dash cluster installed. Few things have changed....
When I go into reverse, I get a beeping noise telling me I am in reverse
If I go above 70, I get 4 beeps, assuming I am going over the speed limit.
Anyone else have these warning signals?
Old Jan 10, 2008 | 01:35 PM
GidyupGo's Avatar
GidyupGo
Default RE: Overspeed warning?
Not on my GT. Maybe it's something they put on 6 bangers to let them know they are approaching the 113 mph top speed.
Old Jan 10, 2008 | 01:51 PM
WPsharpshooter's Avatar
WPsharpshooter
Overspeed warning ???? That thing got granny low and air brakes too.... lol
Old Jan 10, 2008 | 02:02 PM
howarmat's Avatar
howarmat
s197 Junkie
You need to take it to ford and have them reflash the cluster with the "as built" data. The chimes will go away
Old Jan 10, 2008 | 02:54 PM
noober's Avatar
noober
Also your parking break light may be engaged even when the break is depressed, and you'll hear other chimes as well. If you don't have TCS or ABS (which I'm SURE you do..) then those lights would go on as well.
Also, your tire pressure sensor may activate.
As howarmat said, take it to the dealer to get it "as-built" flashed. I have an appointment for mine this friday. Lovin the new mycolor cluster. ^_^
Old Jan 10, 2008 | 04:01 PM
157dB's Avatar
157dB
Cut & Paste Expert
+1
Have flashed "as built"
Old Jan 10, 2008 | 04:08 PM
joeymustang's Avatar
joeymustang
my v6 has gone 120 without beeping....or limiting...interesting huh?
Old Jan 10, 2008 | 04:09 PM
Cubs17's Avatar
Cubs17
That would get annoying pretty quick!
Old Jan 10, 2008 | 04:22 PM
bhaz413's Avatar
bhaz413
Its actually not that annoyed to be honest. I dont back up often and once I go past 70 it beeps those 4 times and stops, but if I drop below 70 and go past it again, it repetes it self.
Yeah my old one never did that, till I got my new cluster. Doesnt make sense to be honest, but it is an oem cluster too. No warning lights, no performance drop, just gives a friendly beep.
Will the ford dealership charge me for this?
Old Jan 10, 2008 | 04:27 PM
banka87's Avatar
banka87
ORIGINAL: joeymustang
Our driveshafts tend to explode around that point. I reccomend not doing that without an aluminum one in the future.
