car sucking
So my 2005 GT with 23K miles seems to have sluggish performance... Extremely full of sootishness in the tailpipe, thick. Bad gas mileage.
I have CAI + bama, cmdp, loudmouths, DS, shorties,have seafoam cleaned a few times, nothing special.
Ideas?
Ideas?
Sounds like you have a rich condition. Check the air filter for dirtyness, and maybe re-flash but I can't see how a tune is going to change over it's lifetime unless of poor quality.
How long has this been occurring? The last tank or 2 of gas? Had a friend that got a batch of fuel that smelled like a gas/kero mix and his car stunk and ran like crap. If not, I'd reflash first as mentioned above.
ORIGINAL: GidyupGo
The soot in the pipe indicates he is getting too much fuel, not starving it.
ORIGINAL: mlcrycc
fuel filter replacementand clean the throttle body....???????
It's probably just in your imagination more than anything. I would put the car on the dyno if you think it is feeling sluggish and then go from there. The soot is definately there beacuse of your tune from bama which is from adding more fuel, but does not necessarily mean you are getting too much. I'm sure that could play a part in your gas mileage having a more aggressive tune, but again put the car on a dyno and record your gas mileage after each fill up!
-Jeff
ORIGINAL: ohnoesaz
Ideas?
Ideas?
+1 to Gidyupgo - You're running RICH
Stop with the unecessary seafoaming, you're just gonna eat your seals up. Check/clean your plugs, replace fuel filter, Clean or replace your air filter, reflash your tune (your car adapts over time) then see how it goes.
ORIGINAL: blackout
You should still change the fuel filter if you haven't changed it yet.
-Jeff
ORIGINAL: GidyupGo
ORIGINAL: mlcrycc
-Jeff
He's getting too much fuel.
Be it either from not enough air, bad tune, or an incomplete combustion process. So, re-flash, clean air filter, or replace plugs. That's ALL it could be.
