MGW question / random
Old Jan 13, 2008 | 02:28 AM
jstone3769's Avatar
jstone3769
Default MGW question / random
Thanks for the help in my earlier thread, install wasn't hard at all.
I just installed my MGW shifter (I love that thing ) and my JLT CAI (and this one too)from bamachips and I have a question about the MGW, all of the install docs say the same thing...
from tacobill's guide:
28. Install the shift **** shaft into the handle bracket.
Align slit in shaft to slit in handle bracket for insertion.
Height of shift **** can be adjusted at this time. Make sure it’s within the range of the slit.
my problem is that my handle didn't have a slit of any kind; any ideas?
Old Jan 13, 2008 | 07:25 AM
NJ3's Avatar
NJ3
Default RE: MGW question / random
The original batch of MGW shifters had a shaft with the slit; the new shafts don't have a slit. The old shafts were three pieces, a shaft, a rubber sleeve over the shaftthen a metal sleeve with a slit over the rubber.The three piece shaftwas supposed to reduce noise but George with MGW determined it wasn't needed.
Old Jan 13, 2008 | 08:26 AM
mlcrycc's Avatar
mlcrycc
This is what they are referring to. You can see the two slits aligned in this pic.....
[IMG]local://upfiles/13557/19FE8A99676B447789BD96E487AC0D24.jpg[/IMG]
Old Jan 13, 2008 | 10:48 AM
jstone3769's Avatar
jstone3769
I'm pretty sure NJ3 got it right, no slit of any kind...
the mount in the pic that mlcryccdoesn't even match mine.
thanks for the help guys
Old Jan 13, 2008 | 10:55 AM
mlcrycc's Avatar
mlcrycc
ORIGINAL: jstone3769
Yes, NJ3 is correct. The current shift arms are different from the original. The one I showed the pic of is one of the original mounts...
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
