Failed NC State Inspection OBD Test
Old Jan 13, 2008 | 12:33 PM
ApexStang's Avatar
ApexStang
Default Failed NC State Inspection OBD Test
So, I have the following performance mods:
C&L Racer Intake
Off Road H Pipe
Brenspeed SCT Tune
Flowmasters
Whatis required for me to pass the Test? Should I just plug in the SCT and return it to the stock tune? If so, how long do I need to drive the car for the codes to clear?
Apex
Old Jan 13, 2008 | 12:37 PM
Fallout's Avatar
Fallout
Default RE: Failed NC State Inspection OBD Test
i would assume the OFF ROAD H would be a problem...no cats and all..
Old Jan 13, 2008 | 12:40 PM
smythge's Avatar
smythge
ORIGINAL: Fallout
I was thinking the exact same thing.
Old Jan 13, 2008 | 12:45 PM
ApexStang's Avatar
ApexStang
I was with the tech the entire time. They did not do a visual for the cats. It was the OBD that failed. I'm assuming that my Tune has the O2 Sensors turned OFF so I don't get a check engine light. I guess that makes it fail the OBD Test as well? Should I just install MIL Eliminators and turn the O2 sensors back on?
Would that solve the problem?
Old Jan 13, 2008 | 12:50 PM
howarmat's Avatar
howarmat
s197 Junkie
You will have to email brent and have him write you an emissions friendly tune.
Old Jan 13, 2008 | 01:07 PM
acstone7's Avatar
acstone7
ORIGINAL: ApexStang
did they start the car? [sm=drooldude.gif]
Old Jan 13, 2008 | 01:17 PM
marcuskeeler's Avatar
marcuskeeler
I'm a little surprised that you were not informed the sensors were switched off (if they are). Even so, I would have thought you could install your stock tune which will re-enable the sensors, no?
ApexStang's Avatar
ApexStang
Car was started and the OBD was plugged in. Is everyones recomendation to just call Brenspeed and see what they say?
Old Jan 13, 2008 | 01:21 PM
ApexStang's Avatar
ApexStang
ORIGINAL: marcuskeeler
If I remember correctly, I remember Brenspeed telling me they would disable the O2 / Check engine light in the tune they provided so I could run the Off Road H Pipe.
I guess I could reinstall the tune, just not sure if that will fix the problem. If I reinstall the tune, then it will still throw codes because I don't have MIL Eliminators installed.
Old Jan 13, 2008 | 01:22 PM
mpatilla's Avatar
mpatilla
I hate inspections!
