Replacing stock grille pony
i decided ot take a pic of my old grill to show you the back off it(since it was just sitting a box in the next room), now even though i have a 4.0 that orignially had the pony package grill i assume the emblem is held on the same way, you can see the little peg like thigns sticking through that you need to remove to pull it off, and i assume there is 3M tape on it as well, but using a screwdriver or something should allow you to pry it off, then you just put the new one on the same way, or if you want to make the new one easy to remove in the future(who knows if you ever change your mind on it) break the tabs off the back and only use the 3M tape, plenty strong enough to stay and will come back off with little trouble
[IMG]local://upfiles/82297/8D58A61C5EF34D938369253CC8142CC2.jpg[/IMG]
inyadreems
Aug 21, 2015 09:10 AM
Steve@CJPP
CJ Pony Parts
Aug 19, 2015 08:52 PM
