HELP WITH WHEELS
Old Jan 24, 2008 | 11:31 AM
sandy's Avatar
sandy
Default HELP WITH WHEELS
Hopefully there's some wheel gurus out there that can help me. I'm looking at buying the gr500 wheels - 18"x9.5 (shelby gt500 setup). I want tires, front 255s and rear 285s(also shelby setup). The offset on the wheels is advertised as 50mm. Here's my question: will that offset work for both front and rear, or is there a different offset that has to be used for the front? Also, I assume the 285s will go on these 9.5 inch wheels???
Old Jan 24, 2008 | 11:51 AM
brad281's Avatar
brad281
Default RE: HELP WITH WHEELS
Those wheels will fit fine on all four. 285s can go on a 9.5" wide. 255s might be a touch small for a 9.5 though? If you want the same setup you could go with the same tire package as on the gt500. Are you sure you want to go with a staggered fitment on the tires? Tires will last longer going witht he same and just rotating. I see you already have a little suspension work.
Old Jan 24, 2008 | 12:00 PM
sandy's Avatar
sandy
thanks Brad; I miss-typed on the wheels. I'm looking at the same setup as shelbys gt500 (the gt500 wheels). Just not sure if those wheels are all four the same offset. Yeah, I know I'll lose tire time with the staggered tires, but I want the "look".
Old Jan 24, 2008 | 12:26 PM
brad281's Avatar
brad281
7.125" backspacing. All the wheels I seen on ebay for the gt500 style were all the same. So the offset wouldn't be an issue. The rears should appear wider due to the wider tires. What aspect ratio do you plan on going with?
Old Jan 25, 2008 | 11:44 AM
sandy's Avatar
sandy
What is aspect ratio?
Old Jan 25, 2008 | 12:07 PM
oshkoshbajawsh's Avatar
oshkoshbajawsh
I ♥ Acer
why dont you forget about the gt500s and go with these.
http://cgi.ebay.com/ebaymotors/Davin...em190193280895
Old Jan 28, 2008 | 12:08 PM
sandy's Avatar
sandy
Does anyone know of a on-line dealer that sells the GT500 wheels other than American Muscle?
Old Jan 28, 2008 | 12:43 PM
brad281's Avatar
brad281
Ebay store: emustangparts. $699 plus 100 shipping.
Old Jan 30, 2008 | 01:13 PM
sandy's Avatar
sandy
thanks brad---------
Old Jan 30, 2008 | 01:30 PM
Pantera72's Avatar
Pantera72
ORIGINAL: sandy
Aspect ratio is the sidewall. It is the amount of rubber between the pavement and the rim, or what you would see if you looked at your car from a direct sideview. The more aspect ratio you have the beefier your tires will look.
