Vortec vs. Procharger
Ok I am ordering one or the other just cant decide... whats the difference between liquid and air-to-air intercooling? I heard good things about both but dont know the pluses and minuses about either so give me some input.
Also Paxton makes a air-to-air intercooler but I havnet heard good things about Paxton so give any imput you got on them too
thanks everyone,
James
thanks everyone,
James
ORIGINAL: brad281
I thought you were going with a kb or whipple?
Are you looking ata P1sc? I would not rate that higher than a twin-screw for track use.
You said it will be a race application then you should have the big D1sc if you want a ProCharger
ORIGINAL: zkiller
ORIGINAL: Ortoch
the F1A actually is what I am looking at
ORIGINAL: zkiller
) is the way to go for track use. The P1 will no way beat a good TS set-up. The downside is the air to air cooling of the Procharger will be a driveability factor with big boost especially in warmer climates and heavy street driving. Are you doing a motor build? What kind? If you are staying on your motor and doing lot's of DD, then the Vortech hands down IMO.
