Spring Performance Plan
Old Jan 26, 2008 | 12:32 PM
Be Rad 13's Avatar
Be Rad 13
Default Spring Performance Plan
Here's my performance plan foran '06 GT Auto...goal is to have this all done by spring. My preference would be to wait and do 1 tune after everything is installed, so it can account for the new gears/exhaust and TC as well. Are there any issues if I wait? Also, should I tune at 87 octane still, or would I be better off going to 89 or 91?
1 -- Corsa Exhaust
2 -- 3.73 Gears
3 -- Torque Converter
4 -- CAI
5 -- Brenspeed Tune
Anything else I'm missing? I don't want a supercharger, but if there's something else fairly cheap that'll be noticeable, I'd be open for suggestions.
The sweet thing is that I feel like my GT has got some serious nuts already as stock....I can't wait to get these bad boys on too.
Old Jan 26, 2008 | 12:37 PM
rshamekh's Avatar
rshamekh
Default RE: Spring Performance Plan
I have an '05 Auto.
Let me tell you that the CAI/tune, will make it a complete different car! Go with the 93 Race tune from Bamachips.
Doug will update your tune for free whenever you get new mods.
Then you should go with Exhaust, 3:73s, TC, Spydershaft, UDPs, CMDPs, etc... The list is endless. But you should start with a CAI/tune. I recommend Bamachips, because it's been said that Doug makes the best tunes for Auto's.
Old Jan 26, 2008 | 12:49 PM
downriverT's Avatar
downriverT
Good list. You could add udp or a a driveshaft to that list. If you don't have any plans of a supercharger cai/tune is the way to start out.
Old Jan 26, 2008 | 12:55 PM
Be Rad 13's Avatar
Be Rad 13
I'm actually not familiar with the driveshaft or udp or cmdps....what are they, and how do they work?
Old Jan 26, 2008 | 01:04 PM
exx1976's Avatar
exx1976
Driveshaft = 1 piece driveshaft to replace the factory two-piece unit. They weigh less, thereby freeing up HP that you already have. Some have claimed gains of up to 5-10 RWHP, but again, this isn't NEW power, it's simply power you already have that is being tranmitted to the pavement in a more efficient manner. No tune required, but there is suspension work required of you are lowered to correct the pinion angle.
UDP = underdrive pulleys. Same thing. free up HP you already have byturning your belt-driven accessories slower. No tune required.
CMDP's (Charge Motion Control Valve Delete Plates) - they have been debated all over the place. Some claim they only provide power in higher RPMs, some claim they actually cause less power in lower RPM range.. I don't know. Don't really have an opinion on them. However, regardless, they do require a tune.
HTH.
PullTab
Oct 30, 2015 08:46 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
