Relocation brackets for stock height?
Old Jan 30, 2008 | 10:23 PM
ohnoesaz's Avatar
ohnoesaz
Default Relocation brackets for stock height?
Will it help? Seems like the downward angle from the chassis to axle would be a big help with wheel hop, as aftermarket LCAs haven't helped at all. True?
But... does it matter if my aftermarket LCAs are fixed length?
Im looking at the BMR bolt-in relocation brackets with 2 hole mounting options
Old Jan 30, 2008 | 10:24 PM
sailing220's Avatar
sailing220
Default RE: Relocation brackets for stock height?
My car is stock height and the LCAs helped a lot alone...
I got Relos and they helped even more.
Old Jan 30, 2008 | 10:53 PM
ohnoesaz's Avatar
ohnoesaz
So having fixed length LCAs wasn't a problem with the reloc brackets? What brand LCAs do you have? And yeah maybe my CHEs have helped but its still horrible.
Old Jan 30, 2008 | 11:19 PM
Black GT's Avatar
Black GT
I have BMR tubular LCA's with the spherical bearing / poly bushing combo.
I installed them along with the BMR HD rear sway bar.
Now my wheel hop problem is pretty much non-existent and I have better traction especially when cornering uphill. (One of my wheels used to easily break loose on uphill corners from a stop, now they both stay planted).
Old Jan 30, 2008 | 11:28 PM
66FB06GT's Avatar
66FB06GT
ohnoesaz,
I see you are a Texans fan, and so I guess you must live in H-Town. I am in Houston and got a deal on LCA's and CHE relo brackets from DynoJoe.com. Thatare the only suspension mods I have doneto this point (only had the car 3 months) and it completely eliminated a huge wheel hop problem on my car. I still have a huge traction problem through 1st and 2nd when launching it hard, but I think everyone w/o DR or slicks has that problem. It did allow me to launch much harder w/out spinning though.
Old Jan 31, 2008 | 06:47 AM
vack75's Avatar
vack75
Can I ask why your CHE's did not help? I'm going to be buying a set here soon with the anti squats.
Are you still experiencing wheel hop or are you not able to hook up with street tires?
Old Jan 31, 2008 | 06:52 AM
jmk3's Avatar
jmk3
Lowering your control arms will increase your straight line grip but will hurt your handling, its pretty far down on the 2 hole brackets for a non lowered car, maybe consider the Steeda brackets that have 5 holes & allow you to go back to stock without removing brackets, the downside is they must be welded in on an allignment rack, the up side is I am not convinced that other aftermarket brackets maintain proper rear axle geometry as far as square to the body.
Old Jan 31, 2008 | 06:57 AM
moosestang's Avatar
moosestang
Let's not confuse wheel hop with zero traction. I have che lca's and relo brackets and I have zero wheel hop even with the whipple HO and drag radials. I can still spin the tires in 1st, but the tires don't leave the pavement.
Old Feb 1, 2008 | 10:00 AM
66FB06GT's Avatar
66FB06GT
The CHE's did help a ton. As I stated, it completely eliminated the wheel hop. Now when I launch hard it is a smooth spinning instead of the harsh hopping I had before. I was just saying that it is a good upgrade, but for most (if not) all it will help traction too but traction is still a problem with hard launches.
At this point the only thing to allow hard launches w/o loss of traction would be DR's or slicks. I just think some people are under the impression that installing the anti-squats and they can launch their car at 3K+ and not have traction issues.
mtgldr
Feb 3, 2024 09:00 PM
Oct 7, 2015 07:02 PM
Sep 17, 2015 07:57 PM
Sep 16, 2015 07:53 PM
Sparks_88
Sep 8, 2015 01:06 PM
