Getting a garage...Question
Old Feb 4, 2008 | 07:43 PM
hammeron's Avatar
hammeron
Default RE: Getting a garage...Question
i'm jealous, i want a garage with a high
ceiling and a four point lift
pics when your done, please
Old Feb 4, 2008 | 08:40 PM
SatinSilverStang's Avatar
SatinSilverStang
t of the ucoatit site
Logos and Vinyl Graphics Typically applied under a final UGloss-AF clear topcoat, logos may be "painted" into the floor using UCoat It materials of contrasting color or a high-quality, two-part urethane automotive paint. Vinyl graphics are another alternative. When using vinyl it is important to use a high-quality, UV and chemical resistant material typically used for outdoor signs. Printed or metallic finish vinyls may be used provided they are finished with a chemical resistant laminate. Your local sign shop should be able to help you select the best material. Let you sign shop know you will be using a solvent-based (Xylene) clear coat over the material. Always test any material prior to application to ensure compatibility with UCoat It floor coatings.
Old Feb 4, 2008 | 08:42 PM
Burnsy's Avatar
Burnsy
nah do 2 point, not having to jack the car up while on the lift to do wheel changes ftw
Old Feb 4, 2008 | 09:02 PM
Wally39's Avatar
Wally39
My brother had piping put in before they poured the floor so he could have a heated floor. It's fed with a hot water heater. He just loves it! No more cold floor or garage! I don't know if you live anywhere it gets cold, but it's a cheap quiet way to do it.
Old Feb 4, 2008 | 09:09 PM
MustangMan64's Avatar
MustangMan64
^^^That is awesome!
Old Feb 4, 2008 | 09:26 PM
Burnsy's Avatar
Burnsy
and yes, please post pics of garage
Old Feb 5, 2008 | 08:44 AM
TAMPAGT07's Avatar
TAMPAGT07
I've got a three car garage, which you can actually get three cars in. I coated the floor several years ago with an oil based epoxy. Approx two years later, I put down another coat. I would recommend an oil based over a latex based paint. I wated about four days untill I pulled my car's into the garage. I also waited several weeks before I would put the car's in the garage with warm tires, just to play it safe. I didn't use the stuff that you sprinkle on the floor, because I wanted a very smooth surface. The floor is extremely slick though when it is wet. In a few months I will probably do another coat, while I redo my garage cabinets. I take alot of pride in my garage and vehicles. I will post some photo's in the future.
Old Feb 5, 2008 | 08:48 AM
blk07gt's Avatar
blk07gt
i want one!!
but being in college doesnt neccessarily permit getting one
sounds nice though keep us posted on the progress
Old Feb 5, 2008 | 09:06 AM
WPsharpshooter's Avatar
WPsharpshooter
Some of you guys need to check out garagejournal.com. They are some really awesome guys over there and if you have a question about a garage, its almost safe to say they have the answer......To the OP, before you put down your floor coating, post up on the journal aboutthe stuff your using. I can assure you someone over there has used it before and can tell you some things about it.........
Old Feb 5, 2008 | 09:37 AM
nh3's Avatar
nh3
+1 on the floor warming and lift.
