do i need adjustable LCA
Old Feb 6, 2008 | 01:22 PM
schapman's Avatar
schapman
Default do i need adjustable LCA
I just installed lowering spring and the back is at 27.25 inches. Are adjustable LCA needed? I may get a new driveshaft adn want o to make sure the pinion angle doesnt need to be changed. I have a V6 also.
Old Feb 6, 2008 | 01:27 PM
PiggySmallz's Avatar
PiggySmallz
Default RE: do i need adjustable LCA
what springs were they? how big of a drop is it? anything over an inch usually requires an adjustment. I installed BMR springs over the weekend, I still need to install my adj. upper control arm, adj. panhard rod and lower control arms with relocation brackets. I'm going to do it friday and get a full alignment saturday
Old Feb 6, 2008 | 01:38 PM
schapman's Avatar
schapman
eibach pro kit about 1.5"
Old Feb 6, 2008 | 01:48 PM
PiggySmallz
mine dropped 1.75 in the back. I would jus get the adjustable control arms, this way you can always adjust it. I'm pretty sure that 1.5 will throw the pinion angle off
Old Feb 6, 2008 | 02:10 PM
Argonaut's Avatar
Argonaut
You can drive the stock drive shaft and Eibach-Pro without adjusting Pinion. It will be fine. If you put in a one-piece DS in future you will want either adjustable Upper or Lower arms at that time.
Old Feb 6, 2008 | 02:29 PM
07mustanggt's Avatar
07mustanggt
You can really get LCA Relocation Brackets if you have just fixed LCA's prolly and get an adjustable upper if further needed. Correct?
Old Feb 6, 2008 | 02:33 PM
PiggySmallz
relocation brackets just re-adjust the angle of the lower control arms to get rid of wheel hop. The adj. upper control arm is for adjusting pinion angle on the driveshaft
Old Feb 6, 2008 | 02:55 PM
schapman's Avatar
schapman
I already have a 1 piece drive shaft. I have the V6 mustang with the stock shaft.
ORIGINAL: Argonaut
Old Feb 6, 2008 | 03:24 PM
JimC's Avatar
Super Moderator
ORIGINAL: schapman
ORIGINAL: Argonaut
What he is referring to is the aftermarket aluminum drive shaft like the Shaftmasters, not the stock V6 drive shaft where you can see the slip joint easily. Everyone refers tothe aluminumas "one piece" when talking about the aluminum - you can really see the 2 pieces of the GT because of the center section that is exposed on that one.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
