Nitrous question....
Old Feb 9, 2008 | 05:16 PM
0NF1R's Avatar
0NF1R
Default Nitrous question....
how bad would a 75 shot kit be for me car? i dont really know about nitrous
Old Feb 9, 2008 | 05:27 PM
bodyman's Avatar
bodyman
Default RE: Nitrous question....
A 75 shot will not hurt your motor, just go to colder plugs and get a tune for nitrous zex's for the nitrous and bamma chip's for the tune you'll be set.
Old Feb 9, 2008 | 07:27 PM
06elnr's Avatar
06elnr
I ran the 75 shot for a long time with no ill effects, I have the Zex kit and it is very easy to install.
Old Feb 10, 2008 | 05:08 PM
D_Gusler's Avatar
D_Gusler
for me, the only difference a 75 made was feeling a little peppier.
Spraying 125 off the line on sticky tires broke my stock clutch[8D]
Old Feb 10, 2008 | 05:12 PM
blk07gt's Avatar
blk07gt
75 shot should be perfectly fine as long as its used correctly
Old Feb 10, 2008 | 05:14 PM
lldsandsll's Avatar
lldsandsll
from what i hear, u dont have to tune for a 75 shot. each 25 increment above that requires pulling out a degree of spark if i remember correctly. go with a wet kit.
Old Feb 10, 2008 | 05:43 PM
bodyman's Avatar
bodyman
To maximize a 75 shot run colder plug's and a tune, a 75 shot will net you 83 h.p.
Old Feb 10, 2008 | 06:05 PM
0NF1R's Avatar
0NF1R
hmmm interesting information from wise gentlemen of the forum......sounds do-able....would someone who has the time, post up a link to the kit that i should get and a link for the tune.....i currently have the diablo predator steeda cai 93 oct tune.........i dont know anytihng about bama chips pr where to go to get it......
and could i have it set to spray on WOT or would that not be a wise thing to do?....what would be the best setup....
thanks in advance for your help
Old Feb 10, 2008 | 06:52 PM
bodyman's Avatar
bodyman
you can find a tune for nitrous and a zex's nitrous system and plug's too if you need them. the zex's kit is only activated at wot. at bamachips.com
Old Feb 10, 2008 | 06:53 PM
jahudso2's Avatar
jahudso2
You probably want a window switch and a throttle position switch so that it will only spray at WOT and between say 3500 and6000 rpms. Then you wont get puddling in the intake if you try to spray with the throttle closed and i dont know how high you want to spray before redline, but one of the other guys with nitrous should be able to tell you.
