New Driveshaft
Old Feb 13, 2008 | 11:04 AM
VirginiaStang06's Avatar
VirginiaStang06
Default New Driveshaft
I tried searching but couldn't find the answer i was looking for. I saw on Brenspeeds site that they have an driveshaft that claims to add horsepower and torque. I was wondering how much gains i could expect and how much this should cost to have installed. Also if there are any other brands that work well with an auto that would be great!
Thanks in advance.
(heres the site)
http://www.brenspeed.com/mustang_2005/driveshaft.html
Old Feb 13, 2008 | 11:18 AM
Hufenstang's Avatar
Hufenstang
Default RE: New Driveshaft
i havent used that specific one, but with my spydershaft i dropped 2 tenths on the 1/4 mi and gained 2mph trap speed. Worth while mod definately.
Old Feb 13, 2008 | 11:25 AM
dirtydeedsinc's Avatar
dirtydeedsinc
It'll add HP and torque to the back tires by removing the loss due to the 2 piece boat anchor that is the factory piece. I've been doing a lot of looking and research and decided on getting the Spydershaft very soon. I have yet to hear of anyone having problems with it and he's running in the 11s.
Old Feb 13, 2008 | 11:30 AM
Pwny's Avatar
Pwny
Get the Spydershaft. Tried and true.
Old Feb 13, 2008 | 11:40 AM
VirginiaStang06
thanks for the fast reply's! but do i need to retune for the driveshaft? I have heard a lot about the sypdershaft, does anyone have a link to where i could purchase one.
thanks!
Old Feb 13, 2008 | 12:12 PM
Argonaut's Avatar
Argonaut
ORIGINAL: VirginiaStang06
thanks!
No retune required. You can PM the man himself "spyder7724" or just go to: http://www.leonardracingproducts.com/drive01.php
One note: The Spyder shaft requires replacement of the pinion flange on the rear diff. Some other shafts have an adapter plate. I'm don't want to get into a discussion of which is better because opinions vary but I will say that the replacement flange type shaft is a more difficult install. If you are doing the install yourself this may be a factor. If you are going to have an experienced shop do it than its probably not a factor. Cost to install should be in the $100 range. Also note, if your car is lowered or you plan on lowering it then in additional you will want to have an adjustable UCA or LCAs so that you can set the correct pinion angle. IMO this is a good thing to have even if your car is not lowered.
Old Feb 13, 2008 | 12:23 PM
rshamekh's Avatar
rshamekh
The spydershaft is definitelyin my near future.
Heard a lot of good things about it, no complaints or problems.
Old Feb 13, 2008 | 01:46 PM
VirginiaStang06
I could probably get gears and pullies installed for the price of a new driveshaft installed. Which would have a better performance gain? Thanks for everyones replys.....Hopefully i can have one ordered by the end of the month.
Old Feb 13, 2008 | 01:50 PM
Mustang3GT07's Avatar
Mustang3GT07
ORIGINAL: Pwny
+1
Old Feb 13, 2008 | 02:26 PM
VerginaStang's Avatar
VerginaStang
Anyone running the spydershaft with an automatic tranny? What are your opinions?? Any vibration?
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
FivePointToTheOh
Sep 14, 2015 03:35 PM
