enlighten me on LSD
Change my rear tires and got 275/40/r18 n555 but i still cant seem to solve the traction problem. I mean my car doesnt hook up well from a dig.
Heard the lsd will help significantly. What do u guys think? and what is the best lsd brand? (money is not a problem)
Also can u suggest wht else i can do to improve traction from a dip. (already have lca and uca)
Nasser
Nasser
LCA Relocate brackets.
Practice makes perfect. If you are looking for great traction on the street you will be searching for a long time. The relocate brackets and good tires should be good for 1.8x 60' on a well prepped track.
You can also remove the front sway bar to help weight transfer, different springs/shcoks in the back.
The biggest two things are going to be tires and practice.
What are the street names/slang terms for
LSD?
Acid, Doses, Hits, Microdot, Sugar cubes, Tabs, Trips .
What is
LSD?
LSD is the most common hallucinogen and is one of the most potent mood-changing chemicals. It is manufactured from lysergic acid, which is found in ergot, a fungus that grows on rye and other grains.
What does it look like?
LSDis usuallyfound on "blotter" paper (paperthat is perforated into small squares). The squaresor "tabs" mayhave be colored or have images printed on them.LiquidLSDisa clear liquid, usuallyin a small container, tube or flask. LSD canalso be found inthin squares of gelatin.
How is it used?
LSD is taken orally. Gelatin and liquid can be put in the eyes.
What are its short-term effects?
The effects of LSD are unpredictable.They depend on the amount taken, the user's personality, mood, and expectations, and the surroundings in which the drug is used.The physical effects include dilated pupils, higher body temperature, increased heart rate and blood pressure, sweating, loss of appetite, sleeplessness, dry mouth, and tremors. Sensations and feelings change much more dramatically than the physical signs.The user may feel several different emotions at once or swing rapidly from one emotion to another.If taken in a large enough dose, the drug produces delusions and visual hallucinations.The user's sense of time and self changes.Sensations may seem to "cross over," giving the user the feeling of hearing colors and seeing sounds.These changes can be frightening and can cause panic.
What are its long-term effects?
Some LSD users experience flashbacks, recurrence of certain aspects of a person's experience without the user having taken the drug again.A flashback occurs suddenly, often without warning, and may occur within a few days or more than a year after LSD use.Most users of LSD voluntarily decrease or stop its use over time. LSD is not considered to be an addicting drug because it does not produce compulsive drug-seeking behavior like cocaine, amphetamines, heroin, alcohol, or nicotine.
What is its federal classification?
Schedule I
ORIGINAL: one eyed *****
LSD?
What is
LSD?
How is it used?
Schedule I
LSD?
What is
LSD?
How is it used?
Schedule I
ORIGINAL: GidyupGo
One popular acid of choice in the late 70's was SNOOPY. Don't ask me how I know.[8D]
