Alignment after Eibach Pro?
Old Feb 25, 2008 | 01:20 PM
GTstangB.F.D.M.'s Avatar
GTstangB.F.D.M.
Default Alignment after Eibach Pro?
hey guys...
just wondering if any of you got your alignment checked after installing the eibach pro.. considering doing this, but dont want to skip the alignment and watch some good 'ol shouler wear occur
Old Feb 25, 2008 | 01:25 PM
99flhr's Avatar
99flhr
Default RE: Alignment after Eibach Pro?
Mine required alignment after install.
Old Feb 25, 2008 | 01:29 PM
sonnier's Avatar
sonnier
I needed to add camber bolts to get the alignment in spec.
Old Feb 25, 2008 | 01:39 PM
GTstangB.F.D.M.
damnit.. how hard is that to do.. i dont know much about alignment other than toe in etc.
is it worth it to even lower it?
Old Feb 25, 2008 | 01:47 PM
TX007's Avatar
TX007
Installed mine just a few weekends back with my neighbor who is a suspension guru.
Not pulling either way at the present time, he said since it is not pulling to give the
springs a few hundred miles to "settle" then rotate tires and have the alignment checked.
Old Feb 25, 2008 | 01:50 PM
ink003's Avatar
ink003
definitely get an alignment after installing the pro kit - you may not need camber bolts (i didn't), but wear will be uneven and the handling will be diminished in quality without an alignment. it's $100 well spent. if you're gonna lower, do it right
Old Feb 25, 2008 | 01:53 PM
99flhr's Avatar
99flhr
ORIGINAL: TX007
That`s probably good advice, just keep in mind that lowering the car is going to change "camber". Pulling is caused by "caster" angle
A car can pull andNOT wear tires irregularly
A car can wear tires and NOT pull
So, don`t count on straight tracking as a guarantee that your alignment is correct.
Old Feb 25, 2008 | 02:17 PM
ThumperMX113's Avatar
ThumperMX113
Any time you lower or lift the front of a vehicle, you're going to need an alignment. I lowered my girlfriend's car with the Steeda Ultralites and didn't need the Camber Bolts to get the car back in spec. Personally, I'd get the alignment done immediately after. Most shops have a 6 months warranty so just bring it in a few months to have them re-check it if you're worried that the springs settled.
Old Feb 25, 2008 | 03:01 PM
Delt55's Avatar
Delt55
I had to align mine after install. The toe was out of spec. Did not need a camber kit or caster adjustment. But its definetely worth doing an alignment, also loved the way it looked and handled afterword.
Old Feb 25, 2008 | 03:12 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: GTstangB.F.D.M.
just don't get a side exit exhuast system. There's been a few posts about lowered cars and a side exit exhaust and clearance issues as in only a couple inches off the ground.
