Sponsored by:
Sponsored by:
Passenger Side Door Handle Rattle
Old 03-27-2008, 10:32 AM
Hicompression
Hicompression's Avatar
Default Passenger Side Door Handle Rattle
Just for clarification, for those of you that have had the door handle rattle and fixed it...please click on the link below. Is it the panel cover listed as #8 in the drawing the part that the foam tape was used on? And how did you remove this cover. Thanks!
http://www.swaaggs.com/documents/door_trim.pdf
Hicompression is offline
Old 03-27-2008, 11:03 AM
theresa
theresa's Avatar
Default RE: Passenger Side Door Handle Rattle
This is the little black "credit card" thingie behind the inside door handle?
Both mine rattle. I don't make it down the street before I have to move it
backwards.
theresa is offline
Old 03-27-2008, 11:11 AM
Hicompression
I think you are talking about the #3 cover in the link above. My rattle is coming from the #8 cover which is behind the door "pull" handle. Anyone else? How do you remove #8?
Old 03-27-2008, 11:14 AM
oakman
oakman's Avatar
I pulled that cover and put some dynamat on the backside of it - problem solved.
oakman is offline
Old 03-27-2008, 11:23 AM
Hicompression
Sooooo....how did you remove it. Does it just pop off. Did you use a flat bladed screwdriver or did you use your fingers to pull it off?
Old 03-27-2008, 11:25 AM
ckone0814
ckone0814's Avatar
ORIGINAL: oakman
Both of the mycovers (on the inside behind door handles) rattled and I fixed them in a similar way.
ckone0814 is offline
Old 03-27-2008, 11:28 AM
Hicompression
Guys...you're killing me...tell me how you removed that panel!
Old 03-27-2008, 11:38 AM
ckone0814
ckone0814's Avatar
ORIGINAL: Hicompression
Just put some foam behind it and put it back on. It's easy!
Old 03-27-2008, 11:51 AM
Hicompression
ORIGINAL: ckone0814
Dude...aaaargh!...HOW DID YOU REMOVE IT! Sorry for yelling...
Old 03-27-2008, 11:55 AM
ckone0814
ckone0814's Avatar
ORIGINAL: ckone0814
Ha ha ... couldn't resist .
If I recall correctly,there's a cutout on the inner sidewhere you can slip small screwdriver in and free the catch. Not sure, fixed mine awhile ago.
Quick Reply: Passenger Side Door Handle Rattle
