RE: battery dead or need recharged??
last nite i went to start my car after sitting in my garage for 2 weeks and the dash lites flickered and starter clicked but the car started. so i drove around for 1/2 hour thinking the battery would charge. well it did not. went to start it again and would not start. dash lites flickered and starter clicked again. do i need to trickle charge battery or is there a dead cell. car only has 1800 miles on it.
Its the deaded battery drain.
It happens to all whom dont drive their stangs
for weeks on end. You need a battery shut-off
switch or a battery tender.
Putting a drain on an already dead battery is not
good for it. I would not trust it and would suggest
a new battery.
a new battery.
thanks guys!! i will charge it and try to drive it more often. it's pennsylvania weather and cold and snow alot lately. but if let it sit for a couples days again and it dont start back to the dealership i go again!!! whole another story!!!!
how long did you drive it for, and how fast. To deep cycle charge the battery, the car needs to be moving over 30 mph, at speed, for an extended period of time, an hour or so in your case would probably do it. Idling/city driving will only put a surface charge on..
EDIT: typos
EDIT: typos
+1
Alternators dont charge very well at idle
A105 amp hour battery need to be charged
with 10.5 amps for 10 hours or 5.25 amps for
20 hours or 1 amp for 105 hours and so on...
[IMG]local://upfiles/69445/8D8BAA3CDE9140CA8457A365502F0B89.jpg[/IMG]
EDIT-picture
EDIT-picture
ORIGINAL: 07vbluestang
yes!!! the active anti-theft system $325
